Pearson 36 hull concavity - Page 2 - SailNet Community
 7Likes
post #11 of 15 Old 06-22-2017
Less Senior Senior Member
Re: Pearson 36 hull concavity
Originally Posted by RichH View Post
M - you don't sail it when/while its incorrectly blocked, incorrect blocking is the usual cause of the buckling in such Pearsons. When free floating, the forces onto the hull will be approximately equal.
If the boat was stored/blocked incorrectly for long term or repetitive 'bad' blocking, indeed the hull may have taken a permanent 'set' - but usually rarely so. My suggestion to re-block the boat would be ~prove that the condition was only temporary - due to the undue forces imposed by the probable bad blocking job, and not permanent. ;-)
FWIW - the 'real' problem with most Pearsons of this vintage is zillions of cosmetic (non-structural) osmotic blisters in the underwater gel-coat layer, sometimes superficially into the matting layer ... not a big deal.
If I'm reading correctly, the OP is saying the boat has been in the water 'a few years' and is now in a transport sling. Help me understand how re-blocking would help in this situation? Are you saying that the transport sling may be 'twisting' the boat and causing this?
Ocean- that which covers 3/4 of a world made for man, who has no gills.
seaner97 is offline
post #12 of 15 Old 06-22-2017
RichH's Avatar
On these 'floppy' Pearsons having the lift straps of the travel lift too close towards the keel and not 'out' towards the ends of the boat can induce the same hull compression; thus, momentary resultant buckling.
If you already owned this boat, Id suggest the installation of 1"x1" hat-shaped fiberglass axial stringers along the inside of the hull - mid way to the waterline and parallel to the keel. This is/was commonly done by those who fanatically raced these P's to dampen down the hull flex when 'hard' and aggressive racing; it also served to stiffen the hull for when blocking, etc. (.... but the 'floor' of the damn ice box had to be cut away so to place the stringer 'under' the ice-box).
Bottom line is if you have a 'bad feeling' about this boat ... trust your instincts and walk away - IMO.
seaner97 likes this.
RichH is online now
post #13 of 15 Old 06-22-2017 Thread Starter
Mongo's Avatar
Interesting point, I went back and looked at the photos and the strap was aft of concave area, shown roughly as shiny area on photo. Thanks for all the great advice, everyone.
Mongo is online now
post #14 of 15 Old 06-22-2017
RichH's Avatar
.... a Travel lift with its slings too close the keel will tend to cause the boat to 'hog' .... the weight of the ends will tend to sag downwards as the keel is held firm, relative to the position of 'the ends'.
A same situation would develop when one picks up a floppy thin walled FRG pipe/tube, etc. or vaulting pole by the middle ... the ends sag down.
In thin walled structures this can cause compression on the 'underside' of the pipe/tube/poll (or hull) 'skin'; thus, the propensity to buckling. Buckling is a phenomenon of compression in thin walled, etc.structures; the way to prevent such is to keep the structure in tension ... as would happen with keeping the lift straps towards the ends, the jack stands further apart and away from the keel and placing Vpoppit jack stands at the stern and bow. The other way to prevent is to make hull thicker (stronger vs. compression) and thus better able to resist the potential of buckling.
Uncontrolled buckling in structures is a complex mathematical nightmare where just a few pounds of 'side pressure' against a beam or surface, etc., already in compression, can induce the onset of buckling
hope this helps.
RichH is online now
post #15 of 15 Old 06-22-2017
hope this helps.
I got it from your last one, but this is more detailed. Thanks.
seaner97 is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
RichH
1984 Pearson 34's - cored hull? kprhok Pearson 1 02-21-2016 04:40 PM
Does 1983 Pearson 34 have a cored hull? CapSam Pearson 4 05-21-2015 09:15 AM
Is Hull Cored on 1983 Pearson 34?? CapSam Boat Review and Purchase Forum 6 04-19-2014 04:37 PM
Pearson 26 Hull Number jinjyr General Discussion (sailing related) 2 03-24-2014 09:22 AM
First and new (to us) boat! 1985 Pearson 27 Hull #24 itsaboat General Discussion (sailing related) 13 12-08-2011 08:47 PM
