Yanmar "Starting to use oil" - Page 3 - SailNet Community
 5Likes
post #21 of 21 Old 11-13-2019
Re: Yanmar "Starting to use oil"
Originally Posted by bristol299bob View Post
Pressure in the crankcase (felt at the dipstick and oil fill) is a classic sign of a failed headgasket. Similarly it could be a cracked lock or cracked head. It's also common symptom of a failed PCV if you have that. It could of course be worn rings or valve seals, but more likely that exhaust gas is escaping into the crankcase via headgasket leak or a crack......
All good points. I'm not sure many small diesels have PCV valves, rather just straight breather tubes. A clogged breather would be the very first thing I checked, before surgery. Dirty engines that breath off the valve cover can throw sludge into the tube. Oil flush should be routine maintenance and rarely done by many.
All crankcases have some positive pressure, from blow by, so I'd want to be sure what Dennis is finding isn't normal breather pressure that can't get out where it should.
Jeanneau 54DS
Minnewaska is offline
"Seacock" vs. "ballcock" or "ball valve?" SEMIJim Gear & Maintenance 18 09-02-2013 06:31 PM
2gm 13 Yanmar external oil line "HELP"!! ltgoshen Diesel 2 04-16-2013 02:18 PM
VIDEO: Coast Guard Academy Welcomes "Blue Goose" and "Stormy Petrel" - Patch.com NewsReader News Feeds 0 07-28-2012 08:50 AM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 12:53 PM
