Yanmar "Starting to use oil" - SailNet Community
 5Likes
post #1 of 21 Old 08-12-2017 Thread Starter
I am considering a boat. It has a Yanmar in it from 1985. 2 cylinder.
The owner said it is "starting to use oil" and that in the month of July cruising it used 1 liter + 1/4 liter.
He says it isn't going anywhere, there is no smoke or anything and the bilge is clean.
Ok is this enough to walk away? Is this motor of concern or do many use oil?
Thank you for your responses. Newbie in PNW.
Register1 is offline
post #2 of 21 Old 08-12-2017
JimsCAL's Avatar
Re: Yanmar "Starting to use oil"
Something is definitely not right. That is a lot of oil use. My 3GM30 from 1985 doesn't use a drop all season. I would not necessarily move on, but I would not proceed without a mechanic diagnosing the issue and giving an estimate for the repairs.
olson34 and basssears like this.
S/V First Tracks
1985 Cal 33-2
JimsCAL is online now
The Following User Says Thank You to JimsCAL For This Useful Post:
Register1 (08-12-2017)
post #3 of 21 Old 08-12-2017
RichH's Avatar
At worst, such an engine 'may' need a rebuild ... so If you really like this boat, consider within your offer to include the 'rebuild $$ deduct' within your offered price. You can get such (deduct) estimates from just about any reputable engine dealer.
There are some 'chemical treatments' with which to free-up / release stuck piston rings, cruded-up piston grooves, etc. You may get the owner to agree to do a 'SEAFOAM' in the crankcase oil treatment to see if the undue oil consumption is just a sticking piston rings, oil control rings, etc. --- all at his expense, of course.
If the engine has a PVC valve, that is stuck 'full open', that alone can cause 'oil consumption', etc. etc. etc.
https://seafoamsales.com/how-to-add-...crankcase-oil/
RichH is offline
The Following User Says Thank You to RichH For This Useful Post:
post #4 of 21 Old 08-13-2017
Moderator
MarkofSeaLife's Avatar
Dock
if its using that amount of oil it will not be a cheap fix.
With the reality of a new or rebuilt engine including instalation ... above $10,000
and you dont need the heart ache, stress or uncertainty on your first boat that should be the most exciting purchase of your life.
basssears likes this.
Sea Life
Notes on a Circumnavigation:
People can say they want freedom, but offer them the keys to what chains them, a map to where they want to go,
And they'll turn it down for the cell they know
MarkofSeaLife is offline
The Following User Says Thank You to MarkofSeaLife For This Useful Post:
Register1 (08-13-2017)
post #5 of 21 Old 08-13-2017
Originally Posted by Register1 View Post
....... in the month of July cruising it used 1 liter + 1/4 liter.........
That's a serious warning sign of a major repair to come. Good of the owner to be honest about it.
It's probably best to walk, but any boat you buy will have the potential for unanticipated engine issues. If the owner was willing to identify and correct this serious problem and the rest of the boat was solid, it may be worth continuing. However, for discussion sake, let say only one cylinder has lost compression. Even though repairing that single cylinder may eliminate the oil consumption, it is still a sign of a full overhaul to come.
I'm attracted to an honest seller, if you can get it at the right price to fix the motor, but it still may be more trouble than it's worth.
PhilCarlson likes this.
Jeanneau 54DS
Minnewaska is offline
The Following User Says Thank You to Minnewaska For This Useful Post:
post #6 of 21 Old 08-13-2017
At the right price, where the right price = Value - price of repower/rebuilt, you could have a boat with a brand new or rebuilt engine. Just make sure you really understand the price of repower/rebuilt. We just did it on a power boat with great access and an engine that fit perfectly on the old mounts, etc, and the total cost or repower was at least 1/3 labor. If it's a hard installation involving cabinetry, could easily be more.
If you are new to this, IMHO, find something else. If not, you know a great yard, you know the right mechanics, or you are skilled at doing this yourself because you've done it before, then I'd consider it. Installation of a new engine involves electrics, plumbing, exhaust, control cables, engine mounts, drive train issues (gear/shaft/stuffing box/cutless), and working around cabinetry. Can add up. Hard to touch one thing and not end up fixing other things. For example, we ended up with reconditioned shaft, new prop, new cutless, new stuffing box, and well the gear is old too, so why not....etc....etc......etc. And this thing was in a raised engine box on deck, for easy in-easy out...
Maybe it's something simple causing the oil "consumption" but there are enough really bad reasons I think you need to discount the price to assume re powering to do this deal.
capecodda is online now
The Following User Says Thank You to capecodda For This Useful Post:
post #7 of 21 Old 08-13-2017
Learning the HARD way...
eherlihy's Avatar
In preparation for my trip (starting in 3 weeks!), I have been viewing videos from s/v Escape. (It's kind of like Bevis and Butthead on a boat)
In Episode 10 their Yanmar, which had been using about a quart per month, throws a rod. You can watch it here:
USCG Licensed OUPV Captain, ASA 101/103/104/105/106/114/118 Instructor - Also certified in Marine Electrical Systems
eherlihy is online now
The Following User Says Thank You to eherlihy For This Useful Post:
post #8 of 21 Old 08-13-2017
BarryL's Avatar
Hey,
How many hours did the engine run for it use 1+ liters of oil? If that was in 1 hour something is REALLY wrong. It was as in 100 hours then it's not that bad.
And what has it used since then? Perhaps the oil was low after a change and didn't use that much oil? Or, perhaps the rings are shot and it's burning oil at a high rate. A single data point (used 1.25 liters in July) doesn't tell you much.
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is online now
The Following User Says Thank You to BarryL For This Useful Post:
post #9 of 21 Old 08-13-2017
overbored's Avatar
Consider that a 2 cylinder only holds 2.0 liters of oil using that much oil is way excessive. I had a Yanmar 2 cylinder that had 2500 hours and you could not measure any oil usage between oil changes. plan at least $6-7K for a rebuild and install of a rebuilt Yanmar 2 cylinder of that year.
"GOLD RUSH" PRINDLE 16
overbored is online now
The Following User Says Thank You to overbored For This Useful Post:
post #10 of 21 Old 08-13-2017
Daniel - Norsea 27
Rhapsody-NS27's Avatar
I did a partial engine rebuild of my Yanmar 2GM myself, without prior engine experience. I spent $2,000 on JUST parts! with the rate of labor costs, it could easily cost 3 times that amount for someone else to do the work.
Get a mechanic to look it over before going too far in a purchase process. Compression test might give an idea of what's going on too.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is offline
"Seacock" vs. "ballcock" or "ball valve?" SEMIJim Gear & Maintenance 18 09-02-2013 06:31 PM
2gm 13 Yanmar external oil line "HELP"!! ltgoshen Diesel 2 04-16-2013 02:18 PM
VIDEO: Coast Guard Academy Welcomes "Blue Goose" and "Stormy Petrel" - Patch.com NewsReader News Feeds 0 07-28-2012 08:50 AM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 12:53 PM
