Sabre 36 (another one) - SailNet Community
 6Likes
  • 1 Post By danvon
  • 1 Post By SanderO
  • 1 Post By tempest
  • 1 Post By olson34
  • 1 Post By SchockT
  • 1 Post By justified
post #1 of 9 Old 03-18-2019 Thread Starter
davidpm's Avatar
https://www.dropbox.com/sh/2llhwg4nv...jyG3uCCVa?dl=0
Have you ever seen a 30-year-old boat without deck leaks?
I have not seen one yet. I'm starting to think maybe they don't exist.
davidpm is offline
post #2 of 9 Old 03-19-2019
Re: Sabre 36 (another one)
My 29-year old X-3242 does not seem to have deck leaks to speak of. there were, of course, major leaks around the cabin windows. Replacing the windows took care of that.
davidpm likes this.
danvon is offline
post #3 of 9 Old 03-19-2019
SanderO's Avatar
Mine is from 1985 and has only had a leak at one chain plate that required re bedding. Solved. Did them both. Maybe I should measure the moisture???
davidpm likes this.
pay attention... someone's life depends on it
SanderO is online now
post #4 of 9 Old 03-19-2019
The water in the Bilge is likely coming in through the mast.
As far as other leaks go, they can usually be solved, the question would be: how long were they occurring and how much if any damage was done?
The Chainplate leaks could cause bulkheads to rot if left unattended. Sabre has a vinyl liner over the bulkheads. The one you photo'd looks to be in decent shape, but you should sound them with a plastic hammer. In Fact, I think you should be sounding the decks. The meter is fine, but a hammer will tell you what you need to know too. If all is well, just lift the chainplate covers dig out the old caulk and re-bed every few years.
The staining looks like it could be coming from Stantions ?
One of the the most annoying leaks on my Sabre came from the topside handrails, Which I had to remove and re-bed. I re-potted with epoxy.
That Sabre is a little Pricey IMO. That $ would get you two 35 O'days. ;-) 6' draft is not really small in my neck of the woods.
davidpm likes this.
tempest is online now
post #5 of 9 Old 03-19-2019
Cool Re: Sabre 36 (another one)
That is a high quality brand of sailboat. Price looks quite appropriate. Our boat is an '88 and has zero deck leaks, and was built by Ericson Yachts (another high quality builder).
We are insured for quite a bit more than the asking price on the boat you reference.
As always, get a good survey... and then start the new season sailing rather than starting a multi-year restoration on some cheapie POS that was last described as a "Lot of boat for the money!"
Finding an actual real-life "turn key" boat is rare like the proverbial hen's tooth (insert dinosaur humor here....).
Go Sailing. Life is Short....
davidpm likes this.
1988 Olson 34, by Ericson Yachts.
Sail # 28400
Betamarine 25 (new 2018)
RCYC, Portland, Oregon
olson34 is online now
post #6 of 9 Old 03-19-2019
Tanley's Avatar
Doubt it's the toe rails, Sabre did a nice job engineering the fastening system - although from @tempest 's comments that didn't carry through to the handrails...
Tanley is offline
The Following User Says Thank You to Tanley For This Useful Post:
davidpm (03-19-2019)
post #7 of 9 Old 03-19-2019
No, I was not happy with the Handrail construction. Just screwed in to the Balsa Core.
The toe rail was well done. But there could be a leak coming from a stantion base, inboard of the toe rail.
post #8 of 9 Old 03-19-2019
SchockT's Avatar
My '79 Santana 30, built by WD Schock, had NO deck leaks, or window leaks for that matter. The only leaks she had were through the swim ladder bolts on the transom.
The biggest concern with leaks on deck hardware, as others have said, is damage to the core, assuming the fittings are fastened to a cord area. Things like toe rails and stansions are often bolted to solid fiberglass.
I have never seen a surveyor use a moisture meter. All the surveys I have ever had done they use the ball peen hammer and sound the hull and decks. Moisture meters can be misleading, and certainly dont give the whole story. I have seen them used in home inspections as well, where we have been called in to investigate moisture detected within a wall, and cut open the wall to find it bone dry inside.
Sent from my SM-G960W using Tapatalk
davidpm likes this.
2011 Jeanneau 39i Azura
SchockT is online now
post #9 of 9 Old 03-19-2019
Dave
In general it looks to be a very clean boat and well maintained. A couple comments from your pictures.
1. Engine looks clean except motor mounts might be tried
2. When was the rod rigging done? don't real see evidence of leaks around bases or at the stanchions, but they may have all been re done with the new rod rigging. Water stains on inner walls could be coming from the toe rails/ hull deck connection. But doesn't look to bad.
Just my 2 cents.
Peter
davidpm likes this.
justified is online now
Sabre 36 / Pearson 36-2 patricks Boat Review and Purchase Forum 1 10-03-2018 10:28 PM
Pearson 36 VS C&C 34 VS Sabre 34 VS Sabre 30 miatapaul Boat Review and Purchase Forum 7 04-26-2013 02:39 PM
Sabre 34 Mark II vs Sabre 34 Targa jporesky Cruising & Liveaboard Forum 1 09-17-2011 03:49 PM
Sabre 34 Mark II vs Sabre 34 Targa jporesky Boat Reviews 0 09-14-2011 08:36 PM
Sabre 28 MKI vs Sabre 28 MKII thomasdavison Boat Review and Purchase Forum 5 11-10-2009 04:54 PM
