How much wiggle is OK in a rudder - SailNet Community
 7Likes
post #1 of 22 Old 03-18-2019 Thread Starter
davidpm's Avatar
I've been looking at a few boats recently.
https://www.dropbox.com/sh/2llhwg4nv...jyG3uCCVa?dl=0
I noticed on the boat above the tip of the rudder will move starboard and port without turning about 3/8".
I've been looking a quite a few boats and find that some don't move at all, some less and some more.
I'm assuming any movement is indicative of a rudder bearing issue.
How much is normal?
SanderO likes this.
davidpm is offline
post #2 of 22 Old 03-19-2019
SanderO's Avatar
Re: How much wiggle is OK in a rudder
slop in linkage?
capta likes this.
pay attention... someone's life depends on it
SanderO is online now
post #3 of 22 Old 03-19-2019
colemj's Avatar
Do you mean that the rudder turns around the shaft? In other words, the shaft doesn't turn, but you can move the rudder on it? If so, this is never normal.
If you mean the rudder and shaft turn a bit, this most likely is just lash in the steering system.
Worn bushings will allow the shaft to move side to side. You need to grab it at the bottom and move it left-right, forward-back to determine.
Mark
Manta 40 Catamaran "Reach"
colemj is offline
post #4 of 22 Old 03-19-2019
Not sure what you mean? If I move my rudder, the shaft turns with it, There's no wiggle. There's not much, if any, play in the wheel either; i just replaced all the cables 2 years ago.
tempest is online now
post #5 of 22 Old 03-19-2019
It sounds like he's referring to the rudder wiggling port to starboard, not turning on it's axis. Clearly, if its a small boat with a gudgeon and pintals, this would be pretty common to have some play. For a spade rudder, with a water tight rudder shaft, I've not heard of any play like this being acceptable. May only need a new shaft bearing, but sounds like something is wrong.
Jeanneau 54DS
Minnewaska is offline
post #6 of 22 Old 03-19-2019
david, you need to clarify exactly what is moving. If the entire rudder, including the rudder post, can "wobble" somewhat, that's a worn bearing(s). Wobble without any turning involved.
If the rudder can actually wobble OR turn while the rudder post is not moving, then you have an internal rudder failure. Expensive.
If the rudder and post are turning a little, as one unit, without the helm moving, then you have slop in the steering, probably in the cables.
tempest likes this.
hellosailor is offline
post #7 of 22 Old 03-19-2019 Thread Starter
davidpm's Avatar
Definitely not slop in the linkage.
Not rotating the rudder just direct lateral movement at the bottom end starboard and port about 3/8".
So not a lot but some.
I did not try for and aft to confirm but should have.
It is definitely rudder bearing. My question is how much if any is normal or acceptable.
davidpm is offline
post #8 of 22 Old 03-19-2019 Thread Starter
davidpm's Avatar
Mark
Yes this is what happens?
davidpm is offline
post #9 of 22 Old 03-19-2019 Thread Starter
davidpm's Avatar
Good idea to check that too but that is not what I saw.
See other answers.
davidpm is offline
post #10 of 22 Old 03-19-2019 Thread Starter
davidpm's Avatar
I'm not too concerned about slop in the system as cables can be tightened or replaced.
As hellosailor mentioned an internal failure of the rudder webbing is a big deal but that is not what I saw.
I saw what I assume is wear in the bearing. I don't know how big a job replacing the bearings are and how much wear is allowed and if the surveyor will make a fuss about it.
davidpm is offline
Ok... Ok... Buccaneer Advice needed Socalfive Boat Review and Purchase Forum 19 06-05-2010 05:21 PM
How much keel is OK for the Bay? PalmettoSailor Chesapeake Bay 43 05-19-2009 04:09 PM
Don't wiggle your toes poopdeckpappy General Discussion (sailing related) 2 03-02-2009 06:08 PM
How much draft is OK? Cheetie Boat Review and Purchase Forum 2 04-26-2002 12:22 PM
