Newer SunCat vs older Hereschoff America - Page 3 - SailNet Community
 3Likes
post #21 of 23 Old 04-17-2019
Administrator
Jeff_H's Avatar
Re: Newer SunCat vs older Hereschoff America
Charlie Wittholz designed a number of really nice small catboats. Probably his best known production catboat was the 18 foot Cape Cod Cat, built by Cape Cod Shipbuilding. These were pretty heavy boats since they were pretty fully ballasted for a Cape Cod style Catboat and fiberglass was heavier than the wooden versions. But Charlie also designed a number of similar sized catboats, that were lighter than the Cape Cod. When I was working for Charlie I drew up a simple tabernacle for the Wittholz 17 which was a plywood version of his Cape Cod catboat design. That boat had a wooden mast which made it a little simpler.
I mention this because if you find a cheaper alternative to the Suncat, but was concerned about erecting the mast, you might be able to have a sparmaker install a tabernacle to make raising and lowering the mast easier. One issue with catboat masts in tabernacles is that there are very steep angles to the shrouds and forestay and no backstay putting high loads on the tabernacle so it needs to be well engineered but it can be done.
Given their very high wetted surface, gaff sail plans, and large L/D's, in order to get decent light to moderate air sailing ability with a catboat, an SA/D in the range of 20 or above is required. Most traditional Cape Cod Catboats had SA/D's well above 20.
Good hunting,
Jeff_H is online now
post #22 of 23 Old 04-17-2019
fallard's Avatar
Good hunting,
Marshall Marine, maker of the 18' Sanderling catboat, offers a "mast hinge" option. See https://www.marshallcat.com/sanderling-options.
Since all of the ~18' fiberglas catboats are very similar (e.g., Herreshoff, Cape Cod, Menger), my assumption is that the engineering has been done by Marshall and would be applicable to any of these gaff-rigged cats. You should be able to procure parts from Marshall and have your catboat mast modified locally. BTW, the Sanderling, Herreshoff, and Menger (and probably the Cape Cod) catboats in the 17-19' range all had a single forestay. Some of the Hermann 17' cats IIRC had Marconi rigs requiring shrouds in addition to a forestay. Since traditional catboats have booms longer than the boat, traditional backstays (vs running backstays) wouldn't work.
fallard is online now
post #23 of 23 Old 04-22-2019
Administrator
Jeff_H's Avatar
I don't know whether you saw this but the Chesapeake Maritime Museum had a Herreshoff America donated to the Museum and has it for sale here. #6126 Catboat Tillotson-Pearson 18' - Chesapeake Bay Maritime Museum
Their prices are usually quite affordable for the type and condition of the boats that they are selling.
Do you go newer smaller or older and larger for good caribbean? GCASKEW Boat Review and Purchase Forum 14 07-08-2012 12:15 AM
Sunsail Older Oceanis 373 or Newer Jeanneau 36i? EvanstonJohn Chartering 9 04-22-2010 08:32 AM
Older boat or newer boat - pros and cons Jcody2121 Cruising & Liveaboard Forum 9 03-14-2010 07:31 PM
buying older vs. newer dpierce Boat Review and Purchase Forum 3 08-29-2003 10:06 AM
Older or newer...what''s best gknopp Boat Review and Purchase Forum 4 05-14-2003 09:33 AM
