Can this boat be saved - Page 4 - SailNet Community
 31Likes
post #31 of 37 Old 07-10-2019
Minnesail's Avatar
Re: Can this boat be saved
Originally Posted by davidpm View Post
Add dragging a prop through the water and a diesel tank, square-top main, tiny jib the only remaining question is what else they could have done to make it worse.
A bow thruster?
davidpm likes this.
Catalina 22
on a starboard tack
Minnesail is offline
post #32 of 37 Old 07-11-2019
mstern's Avatar
what else they could have done to make it worse?
Offset companionway?
davidpm and Minnesail like this.
mstern is offline
post #33 of 37 Old 07-11-2019
Administrator
Jeff_H's Avatar
The only remaining question is what else they could have done to make it worse.
A stainless steel bowsprit with a rocna storm anchor and 300 feet of chain, a windlass and a separate AGM in the bow to operate the windlass, radar on the mast, an arch with full solar array, a wind generator, a Imarsat satellite communications dome, catbird seats, a full cockpit enclosure, and a diesel powered margarita maker, (he suggested with tongue firmly in cheek).
davidpm likes this.
Jeff_H is online now
post #34 of 37 Old 07-11-2019 Thread Starter
davidpm's Avatar
You guys are evil creative geniuses.
davidpm is offline
post #35 of 37 Old 07-11-2019
overbored's Avatar
Wing mainsail and hydro foils
would that be built in diesel margarita maker with fresh water cooling or just a light weight portable air cooled diesel margarita maker
"GOLD RUSH" PRINDLE 16
overbored is online now
post #36 of 37 Old 07-11-2019
Administrator
Jeff_H's Avatar
Originally Posted by overbored View Post
Would that be built in diesel margarita maker with fresh water cooling or just a light weight portable air cooled diesel margarita maker?
It would be the built in diesel margarita maker with fresh water cooling and the integral R.O. water maker that is only there to produce the sea salt that is used on the rim of the glass.
Minnesail likes this.
post #37 of 37 Old 07-11-2019
overbored's Avatar
the salt for the rim on the glass, of course. so I presume the RO would also contain a Spray drying chamber that produces dry salt crystals of the exact proper size to make Margaritas. or would that be a separate diesel powered unit
