Around the Americas, help and advice - Page 5 - SailNet Community
 29Likes
post #41 of 61 Old 1 Week Ago
Administrator
Jeff_H's Avatar
Re: Around the Americas, help and advice
Originally Posted by Nate Dennison View Post
I ideally plan to start in Virginia and go round to Alaska, ending with a tribe I work with there. It isn't fully around the Americas. I am looking at a 45ft seawolf, Bruce Roberts 44 offshore, Reliance 44 ketch, and Columbia 43 all for under $20k. Maybe none of them are ideal with more research.
As others have noted you are proposing to sail a long distance, and some of that sailing will be in very tough sailing venues. Those kinds of distances in those types of conditions truly age a boat. The resultant wear and tear of that kind of voyaging can easy be the equivalent of 10 to 20 years of normal boat use, and 10-20 years of normal boat use is enough to wear out several sets of sails, pretty much all standing and running rigging, much of the deck hardware, and minimally require some engine and transmission work. The bigger the boat, the exponentially larger the cost of these components. And those are very large boats that you are looking at.
Disregarding for a moment the suitability of the individual boats that have expressed interest in, if you were lucky enough to find a 45ft Seawolf, Bruce Roberts Offshore 44, Reliance 44 ketch, and Columbia 43 for under $20k, which also had a sound hull and deck, and reasonably intact interior, and rig, to make the kinds of passages that you are proposing, that boat is still likely to need some mix of new sails, all standing and running rigging, much of the deck hardware, and some major engine and transmission work, as well as updated electronics, galley gear, some new hoses and wiring, a proper inventory of spare parts, and so on. Collectively, some partial list of those items would cost minimally somewhere in the $30,000 to $60,000 range and that assumes that you are good with your hands, and have the time to do this work without paying professionals.
It is important to understand that a good designed, structurally sound, and moderately well equipped older 44 footer will typically sell in $40,000 or more range and typically well more than that. An older version of a design that is suitable for distance voyaging and which is anywhere approaching a ready to go condition will be closer to $100,000 and even at $100,000 those boats are likely to need some additional improvements that the improvements alone could easily exceed your $25,000 budget.
When I look at the list of boats that you are considering, they are as scattered in their design intent as bird shot fired into a gale. Normally you would not expect to find these boats on the same candidate list unless the criteria for that list was solely "Boats 44 feet and over that can be bought for less than $20,000." As a quick run down:
45 ft Seawolf: Old school (as in slow and physically demanding to sail). Build quality varied widely on these boats from worse than junkie to halfway decent. These are boats that do not sail well in light air (meaning that you end up motoring a lot of time) and do not do great in heavy air, tending to be rolly and tender relative to drag. If you found one under $25000 it probably needs new decks, masts and deck houses, which were wood on most of these boats.
Bruce Roberts Offshore 44: Design wise this is probably the best design on your list, and depending on the hull material, this was one of Bruce Roberts best designs from that era. BUT (and this is a big BUT) Most of these were either owner built or owner completed kits. There were fiberglass kit versions of this boat that had decent glass work. Most of those were owner finished and so the build quality varies wildly. Compromises were often made on such basic safety items as ballasting (iron boiler punchings in concrete rather than the intended lead shot in slurry), internal structure and framing, rigging engine size and placement, electrical and plumbing systems, propane systems and so on. The owner built boats, and especially the steel, ferrocement, and plywood versions should not even be considered.
Reliance 44 ketch: I know that this boat has a strong following in the traditional boat world, but design wise, the Reliance and the Seawolf would be at or near the bottom of any list (as in below the cut off line of "maybe passable in a pinch") that I would consider for the type of voyaging that your are considering.
Columbia 43: These were some of the best boats that Columbia built and probably the best sailing boat on this list. But they began life as racer cruisers and are a little light for the purpose. If you found one for less than $25000 it is likely to be a project boat that is shot or close to it. A Columbia 44 in that price range is likely to need keel bolts, deck core repairs. remedial structural work, chainplates and so on. One knock on this boat is the Vee-drive which makes it really hard to get to the stuffing box.
But more to the point, this is not an undertaking that should be considered lightly. These are big brawny boats that take a lot of skill to maintain and sail. Clearly, by your own admission you do not have the sailing experience to pick out the right boat, equip it and handle it.
In an ideal world you can find an experienced sailor who would be willing to help you find the right boat, put her into shape, maintain it and act as skipper for food,board, and the adventure of it all. People like that are getting harder to come by but they are out there. Overtime you would ideally learn to become a decent crew, and maybe a decent skipper.
There was a period when several times a month I would receive an email from someone who is considering doing something similar to what you are proposing. I have watched literally dozens of folks go through this. Some are successful in getting 'out there', some discover that they really enjoy sailing and find that they really have no need to 'go out there’; some have discovered that the sailing life is just not for them, and others have not even gotten past the dreaming stage. I apologize that this is a little long and was written when someone else who was just starting to explore moving onto a boat and use it as a base of operations. I respectfully suggest that it might provide a foundation upon which to build an plan that hopefully works for you.
"From what I have seen, the most successful would be cruisers have been the ones who have been somewhat systematic about going. There is a lot to learn before one can safely venture offshore. No one would assume that they could buy a jet airliner take a few lessons and be able to fly around the world. I think most rational people would expect to start with a small plane and work their way up. But for some reason people assume that they can just go out and buy a big boat, take a couple lessons, read a few books, and then go safely cruising.
While there are people who literally taken a few lessons, read a few books and gone out cruising, those that were successful following that route are far more rare than those who have done some kind of apprenticeship. Learning to sail and learning to cruise involves a lot of knowledge and no matter how much you know, there will always be more to learn, but I suggest that you at least take the time to learn the basics, and that just about can’t happen if you buy ‘a big sailboat’ and try to learn.
I find myself saying this a lot lately, but here I go again. We all come to sailing with our own specific needs, our own specific goals and our own specific capabilities. The neat thing about sailing is that we all don’t have to agree that there is only one right way to go sailing. There is no more truth in expecting that there is one universally right answer about many aspects of sailing than there is in trying to prove that vanilla ice cream is universally better than strawberry ice cream. One area of sailing for which there is no one universally right answer involves the amount of knowledge one requires to go sailing. The other is what is the right boat to own.
For some, all they need or want to know about sailing is just enough knowledge to safely leave the slip sail where they want and get back safely. There is nothing inherently wrong with that approach. Lack of knowledge will impact the level of risk, cost, comfort, and performance, but if you want to get out there with minimal knowledge it can be done. But for others, like myself, there is much more to sailing than simply developing a rudimentary knowledge of sailing basics. If you fall into that camp, it is next to impossible to learn to sail really well on a boat as large as the one in question.
While I am in no way suggesting that this makes sense for everyone, for those who really want to learn to sail well, I strongly suggest that they start out owning a used 23 to 30 foot, responsive, light-weight, tiller steered, fin keel/spade rudder (ideally fractionally rigged) production fiberglass sloop (or if they are athletically inclined then a dinghy.) Boats like these provide the kind of feedback that is so necessary to teach a newcomer how to really sail well. Boats like these have small enough loads on lines and the helm that you and your children can all participate and learn together. If there are other people involved, especially if there are children, being able to learn and participate, everyone will be more engaged and less likely to be bored and feel kidnapped.
By sailing well, I mean understanding the nuances of boat handling and sail trim in a way that is extremely difficult to learn on a larger boat. Used small boats generally hold their values quite well so that after a year or even few years or so of learning, you should be able to get most of your money out of the small boat and move on to a bigger boat actually knowing something about which specific desirable characteristics of a boat appeal to you as an experienced sailor rather than the preferences of some stranger on some Internet discussion group.
From the advice that you may have already received and are likely to receive you can tell that there will not be a consensus of opinion on how to go distance cruising.
In any event, I would suggest that at the very least you try to get some sailing lessons. If I were in your shoes, I would sit down and put together a list of all of the things that I would want to know before setting off voyaging such as:
• Boat handling
• Sail trim
• Rules of the road
• Weather
• Routing
• Boat husbandry, repair and maintenance
• Diesel/ gas engine maintenance and repair
• First aid
• Heavy weather tactics
• Legal restrictions on leaving and entering foreign countries
• Navigation, (Piloting, Celestial, dead reckoning and electronic)
• Provisioning
• Radio operators license exam requirements
• Safe and dangerous fish to eat
• Survival skills
• Etc………..
Once I had what I thought was a complete list, I would set up a schedule to try to develop those areas of skill that I was currently lacking. As much as possible I would try to involve all those involved in as many of those aspects as each is capable of understanding. This process could take as little as a year, but more often takes two to three years. The process itself can be very rewarding and can build the kind of bonds that are required to be cast away on that oh so small island that a boat underway represents.
After sailing for a few years you should be able to further define your goals and develop your own sense of what is the right size and type of boat to do what ever you decide to do.
Respectfully,
Jeff_H is online now
post #42 of 61 Old 1 Week Ago Thread Starter
Hey there! I'm pulled over to get some petrol while driving back into the States... It's a lot different responding via the phone.
Thanks for the great tips! I'm basically putting about $700,000 into this project. I have a few chances at deep discounts that the rest would be written off as a in-kind donation to the nonprofit.
I may be unrealistic or hoping for a unicorn to find a good boat for cheap, knowing it would need work first. I want to do the work. I've been buying a flipping motorcycles for the last 12 years. Get ones that need a rebuild and put the work in myself. I would love to do that with a boat. I'm pretty confident in my ability to work on electronics and engines. If I don't find that unicorn boat in the under $25k range, I'll pay up to $200,000. I just always have been for the underdog (so long as it doesn't blatantly add in unnecessary danger).
Thanks everyone! I am going to pick up some books and find some podcasts or something
Nate Dennison is offline
post #43 of 61 Old 1 Week Ago
outbound's Avatar
Current electronics are black boxes. Everything is plug and play. Something breaks it’s cheaper to get a new one then attempt repair.
Standing rigging, staylock terminals(swaging hard to DYI when in remote places), sails, deck fittings, sealants, epoxy , filters etc. is expensive. Most recreational folks need to do routine maintenance once or twice a year. Most maintenance points are really to do after so many hours. Most replacements are scheduled by time of use. So maintenance costs for cruisers and voyagers are several multiple of that for recreational sailors.
Examples. Standing rigging may last decades on a boat use seasonally in a coastal setting. 6 to 8 years is pushing it on a full time cruiser and 5 years is a long time for a voyaging boat.
Previously did oil/filters at most twice a year. Now depending upon the year twice that or more. You will get the worse of both worlds with the program you’re entertaining. Increased UV damage in tropics/sub tropics and need for freeze/thaw protection with that increasing sealant failures and other failures from that. Canvas, zippers, sails, fittings wear and fall much, much faster.
The $700k budget could be eaten up in its entirety just buying and outfitting the boat. Going with an older boat decreases purchase price but doesn’t decrease cost of spares and maintenance items. It also probably increase outfitting costs significantly. Further more you may have great difficulties with getting spares and repair parts depending upon age of the vessel. You need to think about your window. By that I mean how long are you intending to do this? What will be the total time and distance involved? How risk aversive are you? I’m belt and suspenders. Wind vane and autopilot. Life raft and MOM devices. SSB and satphone. Contingency planning eats up big bucks.
In my travels see people on home made steel boats crossing the Atlantic with a home made windvane, no electronics, no watermaker, no raft and a diesel taken out of a road accident mini delivery van. There’s no argument it can be done on the cheap. But the average world ARC or SDR or OCC boat is probably north of half a million with another $100 to 200k in her after purchase as additions and outfitting (spares, tools etc.). Many voyaging boats cost millions. You need to decide where on the spectrum you want to be.
Nate Dennison likes this.
s/v Hippocampus
Outbound 46
outbound is online now
post #44 of 61 Old 1 Week Ago
Administrator
Jeff_H's Avatar
I am glad to see that you have a little more budget than you initially indicated. With an old boat I suggest that plan on spending half of your budget on fit-out and the other half on the boat itself. If I had to recommend to models for what you are considering doing I would recommend the
Kelly Peterson 44 or 46:
The 46 is generally thought to be a better boat, but both are very good distance cruisers. Good copies of these boats can be found for sale in the $60,000 to $90,000 range. I would strongly recommend against one that still has its teak decks. I would also recommend that you use a very thorough marine surveyor to check the deck condition. Also avoid the few of these had wooden masts (most have aluminum spars) https://sailboatdata.com/sailboat/kelly-peterson-44 .https://www.yachtworld.com/boats/197...utter-3576150/
If you are really feeling flush with cash, another of my favorite distance cruisers is the Norseman 447's. These are well built boats that sail very well and are generally set up for the type of thing that you are proposing. Again I would strongly recommend against buying one that still has its teak decks.
https://sailboatdata.com/sailboat/norseman-447 https://www.yachtworld.com/boats/198...utter-3107991/
Good luck,
post #45 of 61 Old 1 Week Ago Thread Starter
I mean, I could wait for my settlement funding and just spend $5 million on a boat. I agree that costs can go up...but I also believe you can keep it within a more restricted budget than the upper numbers you are saying. I had a call with the Bruce Roberts offshore. He said she is ready for sailing, extra sails and fittings. I would need to do a haul out and pay for a marine survey before I was sure...but I believe it can be done. I guess it shows what side of the spectrum I am ok being on. That was still some pretty solid information, so thank you! I think the hardest part about really grasping anything, we all have our own views. Until I find my personal groove, I have to weigh what others have found is best for them.
post #46 of 61 Old 1 Week Ago Thread Starter
So teak is bad? All the posts I have read that mentioned teak made it sound like it was a great thing to have it.
post #47 of 61 Old 1 Week Ago
Administrator
Jeff_H's Avatar
Teak is a marvelous wood in many ways, but for a cruising boat it is a lot of maintenance, and if not maintained water gets into the decks through the fastenings and seams, and then rots out the decks. Many of the Asian boats were constructed with teak decks that were installed over plywood. Sometimes there was a layer of fiberglass between the teak and plywood, sometimes not. Plywood tends to spread the rot in multiple directions, vs balsa core which rots more slowly. So a lot of these older cruising boats started life with teak decks and at some point the teak was removed and the decks glassed over making a cooler deck to walk on and a much easier boat to maintain. If done properly and damaged deck coring was replaced before the decks were glassed.
But also teak is very heavy. The teak decks alone on a 44 footer could weigh as much as 1,500 to 2,000 lbs. Weight does nothing good for a boat. But that much weight that high off the water makes a boat that rolls and heels a lot more than one without it. Some of that saved weight can be used as extra carrying capacity.
post #48 of 61 Old 1 Week Ago
outbound's Avatar
The 447 is a good boat as is
Amel
Tayana
Valiant
PSC 40 or 44
Nautor Swan 46’
Older Passports are also in this price range as is older small Oysters, Hinckley and Hylas
General considerations. Solid hull at least below waterline or metal. Easy to reef. Large carrying capacity which means displacement. Good ground tackle set up.
One offs generally go for less money than a comparable branded boat. If you have a knowledgeable friend and honest skilled surveyor you can luck out with a good Al or converted raceboat. I bought a boat sailed once. It was built for an OSTAR race and fully found for unlimited ocean work. Once race was completed left on the hard in Connecticut. With simple carpentry I converted it to a nice cruiser. I actually made money when I sold her. Most unusual for a sailboat.
s/v Hippocampus
Outbound 46
post #49 of 61 Old 1 Week Ago
PhilCarlson's Avatar
Dock
It's probably been mentioned but bears repeating:
Buying on the cheap and refitting to the level you need will cost more than buying a boat that is at that level already. Then there is the time for refit. Everything takes longer on a boat. Of course there is value to doing the refit if you are hands on because you will intimately know every inch of the boat and its systems.
Sounds like a fantastic project you have planned. Fair winds!
SanderO and MarkofSeaLife like this.
PhilCarlson is offline
post #50 of 61 Old 1 Week Ago
outbound's Avatar
Might want to read the series of articles at “Attainable Adventures “ on buying a boat for under $100K and bringing it up to be a safe blue water boat.
s/v Hippocampus
Outbound 46
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
