Advice on this Cal 20 ? - SailNet Community
Boat Reviews This forum has all types of boat reviews. Take a look, Dream, Agree, Dissagree.... but enjoy.
post #1 of 12 Old 10-24-2015 Thread Starter
Hi,
I acquired this cal 20 and I am wondering if it is salvageable
for someone who doesn't mind a lot of work. If you know
any portions of info, sources, or questions, I would love anything.
I found some neglected screw holes that go through the deck on
both port and starboard. Water has been sitting in there for
I don't know how long ,and the deck is soft
in about a 2x2 foot area inside, and less soft outside.
There are tracks along the deck sides that hold pulleys for the jib line to run through, and from the inside the bolts have begun to pull through, and have caused water damage where the deck makes a 90 degree angle down to the hull at the inside part of the gunwale. So the plates where the side stays attach too are sitting
on soft fiberglass spots. Fixable? Is it possibly to saw out a bunch of the fiberglass and gunnel and then rebuild it?
Otherwise, all of the hardware on the deck is feeling solid, but I can
still tell that the deck between them and their backing plates is not completely dry. Do you think it is possible
to take it all off, repair the fiberglass, and put them back on?
I especially wonder this for where the bottom rudder transom is
fixed to a plywood backing plate below the water line.
I would appreciate any input. I am mostly curious if this is stuff that is possible to fix. And also if you think the cost will be too
insane or any estimable range. I don't mind a lot of labor and I'm hoping to make this thing last a long time!
silversails is offline
post #2 of 12 Old 10-24-2015 Thread Starter
Re: Advice on this Cal 20 ?
Here are more pictures.
post #3 of 12 Old 10-25-2015
Mostly cosmetic, but hard to tell from distant pictures.. seems some repairs have been made on the bulkhead, and perhaps some cracking on the deck supports, but that seems accessible enough to be repairable too.
The rest just looks like elbow grease and cleanup...
Faster is offline
post #4 of 12 Old 10-25-2015
Bleemus's Avatar
I don't consider core repairs to be elbow grease and cleanup.
Sent from my iPad using Tapatalk
Keth
Boat Vinyl Lettering and Graphics
Bleemus is offline
post #5 of 12 Old 10-25-2015
True... missed that part
Faster is offline
post #6 of 12 Old 10-25-2015
Senior Moment Member
SloopJonB's Avatar
O/K, LOTS of elbow grease & cleanup.
Seriously, repairing the core on a boat that size is not a big job (at least compared to my Columbia 43) and it doesn't require any special skills. It also gives you the opportunity to replace the plywood core with something better like balsa or foam.
SloopJonB is online now
post #7 of 12 Old 10-25-2015 Thread Starter
Thank you people for the input so far.
There is this other issue: the trailer is not a correct fit for the boat and it has pushed in the hull a little on the port
and starboard stern. When I wack on the fiberglass around this area, it still feels solid like the rest.
Do yall think the fiberglass is damaged here from this? Or do you think fiberglass can take this much flex?
Do you think they will pop out, sit there?
One thousand thanks in advance.
post #8 of 12 Old 10-25-2015
As much as I like to see boats brought back from the dead and would love to see you do this, it seems like a lot of work will be needing to repair the neglect. You could probably buy a really nice Cal 20 ready to sail for $2000 or less.
Jordan
West Wight Potter 14 "Lemon Drop"
Oceanside CA
jephotog is online now
post #9 of 12 Old 10-25-2015
Bleemus's Avatar
Did you get this boat for free? It appears to be quite abused and personally I wouldn't waste the time to restore it. Appears to have had a chain plate failure or the bulkhead pulled off the hull and a very sloppy amateur repair done on it. If the hull is cored where it is sitting on the trailer you can be assured it has suffered from some delamination with that much deflection. Check the stringers in the bilge and if they have parted from the hull the kell will be wobbling all over the place. Every deck fitting appears to never had been rebedded indicating that you may have core issue of differing degrees at each one. Walk away now. There are plenty of boats in the world.
Keth
Bleemus is offline
post #10 of 12 Old 10-25-2015
SloopJonB's Avatar
The hull isn't cored - those boats were built in the early 60's for the most part. In fact I don't know of any Cal model that had a cored hull - only decks.
The deflection in the hull is common on point loaded areas - I had it happen on my old 26' racer when it was on a boatyard cradle. It comes back to shape once the point loading is relieved. Sometimes it takes a few days but it does come back.
  LinkBacks (?)
LinkBack to this Thread: https://www.sailnet.com/forums/boat-reviews/224674-advice-cal-20-a.html
Posted By For Type Date
Advice on this Cal 20 ? - SailNet Community This thread Refback 10-25-2015 03:38 AM
Cal 25-2 (cal 25mkII) Upgrades Just FYI for Cal 25-2 Owners markdthorne Cal 6 08-30-2017 06:40 PM
Advice on Cal 34 MK III Purchase Reklobe Boat Review and Purchase Forum 7 01-10-2012 01:34 PM
Checking out a Cal 29 - Advice needed jarcher Cal 10 02-01-2010 06:22 PM
Need advice for S. Cal Marina nical General Discussion (sailing related) 4 01-12-2010 07:35 PM
CAL 2-25 aka CAL Mach II for Sale NewsReader Mass Bay Sailors 0 07-07-2007 04:15 PM
