Chris Craft Caribbean 35 - Page 2 - SailNet Community
Boat Reviews This forum has all types of boat reviews. Take a look, Dream, Agree, Dissagree.... but enjoy.
 2Likes
post #11 of 25 Old 04-23-2017
Re: Chris Craft Caribbean 35
I'm going to resurrect this several year old thread because one of these has caught my eye.
The relatively shallow draft of 4.7 feet, the low capsize index of 1.68, and the high comfort index of 37.1 caught my eye after the lines of the boat caught it.
A few questions:
- Were all of these Chris Craft 35 Caribbean models initially built as ketch rigs?
- Any thoughts of the suitability of the space below for living aboard and how the headroom might compare to an Irwin center cockpit?
Movingrightalong... is offline
post #12 of 25 Old 04-24-2017
snake charmer, cat herder
zeehag's Avatar
Send a message via Yahoo to zeehag Send a message via Skype™ to zeehag
i would take the chris craft designed by s and s over the irwin. just personal choice.
check your hull to deck connection and c decks, otherwise-- awesome. i was interested in these before i found my formosa.
formosa 41, cruising tropics
zeehag is offline
post #13 of 25 Old 04-24-2017
Dirt Free
boatpoker's Avatar
I've only ever surveyed one of these and was impressed with the strength of construction. In over 4,000 surveys only one other vessel has impressed me in the same way, The Vancouver 27.
krisscross likes this.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is offline
post #14 of 25 Old 04-24-2017
krisscross's Avatar
That is definitely interesting. How about other Chris Craft boats from the same period, like the Apache 37?
Plato
krisscross is online now
post #15 of 25 Old 04-24-2017
Dirt Free
boatpoker's Avatar
Sorry, that was the only CC sailboat I have ever seen, they are rare in the Great Lakes.
post #16 of 25 Old 04-24-2017
Administrator
Jeff_H's Avatar
A few questions:
I know these boats quite well. (Edit) I knew of two different models of Chris Craft 35 footers with center cockpits. The originals were called 'Sail Yacht 35' and built in the early to late 1960's and were a very nice Sparkman and Stevens design. They were intended as motor sailors but were surprisingly good sailors for their day and configuration. They had a very good reputation as being well constructed. They had a bit of a wierd layout which required walking out into the cockpit to get to the aft cabin. They were built like wooden boats above the deck level with wooden cabin sides, glassed over ply decks and traditional wooden construction for the cabin tops. Rot and deck problems can be expected on one that hasn't been carefully maintained. I would imagine that they would be reasonably good boats in rougher conditions (although they tend to roll through comparatively wide angles).
They pointed reasonably well for their time and type (motor-sailor) but were not especially fast even when compared to boats of that era. (They are obviously quite slow when compared to more modern designs) I have seen them with asking prices as little as $20K but I have no idea what condition that boat was in. Remember these boats originally had gas engines and given the prejudice against wooden boats and gas engines versions with that combination can be hard boats to sell at a fair price. That said I have always been impressed with these boat's solid shipiness and nicely modeled hulls.
These were all sloops. As was typical of a motor-sailor, they were light on ballast and with their shoal draft tended to be a little short on stability. This was usually not a problem with their small sail plan for a boat of this weight and drag. As a motor-sailor they really were not very good sailors in winds below maybe 10-12 knots and with their minimal ballast needed to be reefed pretty early.
In the mid 1960's the original Chris Craft 35 was replaced with a design which used the same hull but which was clearly more of a motorsailer and far less of a sailor. This redesign is referred to as a Caribbean 35. I've sailed on one of these and found them to be very lacking as sailors with pretty uncomfortable motions.
Chris Craft constructed a very fine line of boats in the 1960's that ranged from a 22 foot daysailer to a 42 foot racer cruiser. Most of these were very nicely designed and constructed boats. But the Caribbean 35, which were built in Asia on contract to Chris Craft, do not fit that description. I assisted my former stepfather who did a lot of repair work on one and really thought they were junky boats in terms of build quality with crude glass work, skip tabbed bulkheads, poor system design and installation, crudely assembled joiner work with concealed elements made from non-marine grade plywood and which also included ferrous screws and finish nails, and so on. My step-dad ended up gutting and rebuilding most of the entire interior of that, and reworking the electrical system to meet the standards of that day.
Compared to the prior Chris Crafts and the earlier Sail Yacht 35 these boats lacked the solid wholesomeness that made the original Chris Crafts so appealing. These mid-1960's and later Caribbean 35's are boats that I would would not recommend if sailing ability, and comfort of motion is important to you.
I usually agree with your assessments on build quality, but in this case having been through one of these inside and out, down to the bare hull and back, I respectfully find your comments completely at odds with my own observation. I readily acknowledge that you are the professional in this discussion, but this was probably no more than a 10 year old boat and the kinds of things that we encountered on that boat would never fit the description that you used above. I have run into other models which have had a broad range of build quality within the production run (Morgan OI 41's and Newport 41's for example), but there were so few of these built that it would surprise me that there would be that kind or range of quality deficiencies between one and the other. My guess is that you ran into one that someone had rebuilt.
Respectfully,
Last edited by Jeff_H; 04-24-2017 at 09:01 PM. Reason: bad typing leads to bad typo
Jeff_H is online now
post #17 of 25 Old 04-24-2017
Dirt Free
boatpoker's Avatar
No argument from me Jeff, As I said I've only seen the one and have no idea of it's pedigree.
The one I surveyed was the version where one had to traverse the cockpit to get to the aft cabin but unlike the one you describe, the decks and trunks were conventional cored glass construction, no plywood involved. I'd swear it was a production boat as there was no indication of rebuild other than new wiring and systems.
post #18 of 25 Old 04-24-2017
Administrator
Jeff_H's Avatar
That is interesting about the all glass house and decks. I had heard that there was a third version of this boat which had the original layout (cross over cockpit to aft cabin) and the original trunk cabin, but which had glass decks and house. I was never sure whether that was simply one of the wood deck versions that had been glassed over rather than a production boat. It sounds like it was a production version and that you may have surveyed one of those. Live and learn. Very Cool!
The version that I described as really junky was the last version of this boat and had a doghouse cabin with a small passage under the cockpit seat which raised the seats quite a bit and amplified the uncomfortable motion.
post #19 of 25 Old 04-24-2017
Dirt Free
boatpoker's Avatar
Here she is from the cover page of my survey report. The only non-standard structural item on the boat was the hard dodger added by the owner, In this photo there is something on the aft deck that obscures the aft trunk but I can't remember what it was.
PS. This 1963 boat was (is) a sloop not a ketch and still going strong.
post #20 of 25 Old 04-24-2017
Dirt Free
boatpoker's Avatar
  LinkBacks (?)
LinkBack to this Thread: https://www.sailnet.com/forums/boat-reviews/59300-chris-craft-caribbean-35-a.html
Posted By For Type Date
chris craft caribbean - Virgilio Ricerca Web This thread Refback 07-04-2010 12:30 PM
Chris Craft Caribbean 35 - SailNet Community This thread Refback 10-27-2009 04:47 PM
Chris Craft 35 owners? DeGraw75 General Discussion (sailing related) 10 07-15-2019 12:53 PM
Chris Craft Sail Yacht STEVEinCA Boat Review and Purchase Forum 15 02-20-2017 12:07 PM
Chris Craft 35'' Sail Yacht? Amac Boat Review and Purchase Forum 7 12-20-2013 11:28 AM
Chris Craft Capri 30 Snookums General Discussion (sailing related) 7 11-06-2011 08:14 PM
Chris Craft Catalina 291 Cruiser jszimmermann Cruising & Liveaboard Forum 2 09-27-2008 03:40 PM
