Shore power options - SailNet Community
 7Likes
post #1 of 13 Old 03-31-2017 Thread Starter
Shore power options
Hi everyone,
My C&C 30 MKI currently does not have shore power, something I would like to install. Two questions I have are:
1) what size holesaw is required, and;
2) where would the best spot to install the inlet, I'm concerned with it getting in the way.
Thanks
Tom
tom135ca is offline
post #2 of 13 Old 03-31-2017
Re: Shore power options
Unless you are fairly experienced with marine electrical systems, I'd let a pro handle this for you.
Markwesti likes this.
Catalina 34
chuck53 is offline
post #3 of 13 Old 03-31-2017 Thread Starter
35 years as an industrial electrician, 25 of those in the navy. Extremely compliant with AYBC Regs.
Sure I'm asking for a hole saw size as I'm not near the boat and don't want to make two trips. Question 2 I'm asking for comfort reasons and experience from what others liked on the placement of the inlet. That would be very helpful to me. I have seen some shoddy work by "pro"s. Happy to do it my self.
tom135ca is offline
post #4 of 13 Old 03-31-2017
Then I would say you are well qualified. Have fun.
chuck53 is offline
post #5 of 13 Old 03-31-2017 Thread Starter
You are correct, Please anyone, some useful information on best spot to place the inlet on the boat.
Thanks
tom135ca is offline
post #6 of 13 Old 03-31-2017
Mine is at then stern end of the cockpit on my 30 footer. I like it because it is out of the way. Make sure your cord is long enough to reach the dock if you pull in bow first.
CLOSECALL is online now
The Following User Says Thank You to CLOSECALL For This Useful Post:
tom135ca (09-16-2017)
post #7 of 13 Old 03-31-2017
Markwesti's Avatar
Ours is in the lazarette and a junction box , (teak) was made to house the fem plug . It is completely out of the way of any water , the laz lid has a gap for ventilation so the cord fits nicely in the gap . As far as the hole saw , just get the plug and then you will know .
Westsail 28 , Patricia A
Markwesti is offline
The Following User Says Thank You to Markwesti For This Useful Post:
post #8 of 13 Old 03-31-2017
Sailor
Mine is aft 25 C & C i dont know if all the receptacle are the same mine is a marineco i think, i will be at the boat around 7pm i can measure the hole size and let you know
tom135ca likes this.
Jim_W is online now
post #9 of 13 Old 03-31-2017
Learning the HARD way...
eherlihy's Avatar
I would STRONGLY suggest using a SmartPlug as your 30A shore power inlet.
Most 30A inlets use a 2-7/8" hole saw inlet. I believe that the SmartPlug is compatible with this size inlet hole.
The shore power inlet on my 35-foot boat is on the forward cockpit coaming on the port side. I like this, as it is convenient with a 50-foot power cord regardless of whether I dock bow in, or stern in. Because the cord is 10+ feet forward of the transom I don't have a big coil of useless wire.
Siamese, capecodda and tom135ca like this.
USCG Licensed OUPV Captain, US/Sailing BKB and ASA 101/103/104/105/106/114/118 Instructor - Also ABYC certified in Marine Electrical Systems,
eherlihy is online now
post #10 of 13 Old 03-31-2017
+1 for Smartplug, I've had the old style get cranky after a bit, these seem to make a sure connection every time...
Best location dependent on your primary docking location, if you go bow in, back in, where the pedestal is located...etc. Also best not to be in a position where it takes the brunt of green water on deck....but I assume you know all that....
capecodda is online now
Solar power instead of shore power Ajax_MD Chesapeake Bay 50 07-11-2017 12:47 AM
Shore power - Reverse Polarity and no power at GFCI outlets tatracy Electrical Systems 17 05-20-2014 11:58 PM
Options for Charging batteries while away from the boat OR away from shore power northwestsailor Electrical Systems 3 05-04-2013 12:30 AM
Hooking 110 power cord to shore power? dvuyxx Electrical Systems 16 06-02-2012 10:35 AM
Small Catboat mooring/launching options on CT shore jimbanks02 General Discussion (sailing related) 3 02-20-2008 10:20 PM
HTML code is Off
