Lewmar 16 winch tiny spring clip - Page 2 - SailNet Community
C25 and 250 For Catalina 25 and 250 owners
 14Likes
post #11 of 13 Old 06-21-2016
Senior Moment Member
SloopJonB's Avatar
Re: Lewmar 16 winch tiny spring clip
Use white lithium grease - Gunk is the brand I currently have. It has a texture similar to yogurt. A cup costs about $5 and lasts for years.
It never hardens, in fact over time it gets a bit oily. It will not cause stiction on the pawls so you can use it for everything instead of oiling the pawls (which never lasts very long).
I apply it liberally to everything, wind the winches a bit then pop off the drums and wipe off the squeeze out. Works perfectly and it also quiets the ratchet noise from clink clink clink to tic tic tic.
I tried Lewmar grease once - got a miniature toothpaste tube of it for $17 which was about enough for two winches. Nasty, sticky stuff that made the winch action stiff.
Try the lithium - you'll like it. Can be used for everything on board as well - steering cables, throttle cables, quadrant chains etc. etc.
It even says "Boat winches" right on the container.
P.S. I've used Lewmar springs & pawls in Barients and Barlows. If you change to their pawls be sure to change them all - there are slight variations in size that will result in one pawl carrying all the load.
Minnesail and rbpsnc like this.
SloopJonB is online now
post #12 of 13 Old 06-23-2016 Thread Starter
C25/B235/F39'noob'
excellent, thanks, SloopJonB!
rbpsnc is offline
post #13 of 13 Old 06-23-2016
Stu Jackson's Avatar
Originally Posted by rbpsnc View Post
(also: my winch was impossible to remove; are these Lewmar 16s glued to the topsides?)
You leave them on the boat, you take the tops off the winches.
rbpsnc likes this.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
  LinkBacks (?)
LinkBack to this Thread: https://www.sailnet.com/forums/c25-250/257058-lewmar-16-winch-tiny-spring-clip.html
Posted By For Type Date
Lewmar 16 winch tiny spring clip - SailNet Community This thread Refback 06-20-2016 06:13 PM
Lewmar 40 ST; 1970's Spring Jaw mjasko Gear & Maintenance 9 03-23-2015 01:08 PM
Broken Lewmar Winch rhr1956 Gear & Maintenance 10 12-04-2012 04:32 PM
Lewmar winch Foxsea Introduce Yourself 4 06-06-2011 12:19 AM
lewmar winch parts Kiltmadoc Gear & Maintenance 0 05-16-2010 06:15 PM
Lewmar winch crowns tkringstad Gear & Maintenance 0 10-31-2004 02:16 PM
