Catalina "smooth" gel coat has a pebble grain texture. Is this normal? - Page 2 - SailNet Community
C25 and 250 For Catalina 25 and 250 owners
 3Likes
post #11 of 14 Old 4 Weeks Ago
TakeFive's Avatar
Re: Catalina "smooth" gel coat has a pebble grain texture. Is this normal?
I know I'm coming in late on this, but is it possible that you're seeing osmotic blistering? I have a small sailing dinghy that was stored under a cover for a year, and unfortunately moisture found its way between the cover and the deck. I ended up with small osmotic blisters over part of the deck, which looks sort of like pebble grain. I have left it as-is, because the only solution is to pop them open by hard sanding, dry them out, and redo the gelcoat. That is far more than the boat is worth. What you described sounds similar. Perhaps leaves fell onto your deck and trapped moisture against the gelcoat.
Rick S., Swarthmore, PA
USCG Certified Captain, OUPV and 50 Ton Master
2001 Catalina 34MkII Tall Rig Wing Keel Breakin' Away, Universal Diesel M35B, Mantus 35 lb. anchor, sailing out of Rock Hall Landing Marina
TakeFive is offline
post #12 of 14 Old 4 Weeks Ago
Above 5 knots
Dock
Some notes.
Soft Scrub with bleach is actually, um, soft. It does have mild abrasive, but it wouldn't put a dent in gelcoat.
To damage gelcoat as you you describe would require something of a larger sort, as I've used 80 grit sandpaper to no avail at damaging gelcoat (attempting to smooth).
2 common catalina boats and sorry for my prior sarcasm I was having a bad day... of that vintage (which is honestly quite new if it really is a 1986)... and size...
Catalina 25:
Catalina 22:
Catalina had pretty decent gelcoat process down in their boats by the 1970s, and 1980s they were pros. If you are truly looking at gelcoat (I think you are looking at awlgrip or similar 2 part that has aged), then you can use a wetsand, compound, polish wax method to shine it up... or you can take the REAL lazy approach like I have a couple of times and just polyglow it and go sailing. There will be purists here who say NO NOT POLY GLOW, and I am here to tell you, life is to short to waste sailing time on compound polish wax and repeat, cause every 6 months you'll need to rewax.
MINI MOO, a 1983 Wavelength 24 - she's a fast cow!
SailingUphill is online now
post #13 of 14 Old 4 Weeks Ago
Originally Posted by SailingUphill View Post
Some notes.
Bleach is highly alkaline and will damage gelcoat. As I said, probably not so much, if used once. Probably less noticeable, if the gel cost is already damaged. The issue is not that itís mechanically abrasive.
.......I've used 80 grit sandpaper to no avail at damaging gelcoat (attempting to smooth).
Howís your eyesight?
There is no way that course sandpaper would not leave actual scratch marks. Even wet sanding with superfine paper needs swirl marks buffed out. Maybe the gelcoat you sanded was just that bad to begin with and it simply didnít get worse.
Jeanneau 54DS
Minnewaska is offline
post #14 of 14 Old 4 Weeks Ago
Above 5 knots
Dock
Minni I get your point yes it DOES scratch the gelcoat, but not easily. Gelcoat is not like paint. If there is any thickness to it (the gelcoat) then you can do an awful lot of rubbing to it before it creates a cracking. Impacts maybe, that'd do it. Softscrub with bleach will dry the surface and open the gelcoat to oxidation (more oxidation) which is the reason why you must reseal it to prevent that.
The 80 grit I used, was to level applied gelcoat, then was followed by successively higher grain until eventually compound, polish, and wax to bring it up to a shine. What I call a 10 foot shine, cause after all it was a $7500 boat, that was 40 years old, that had more repairs than the average 70s Ford Pinto.
Minnewaska likes this.
