columbia 34mkII fuel tank replacement - SailNet Community
 3Likes
  • 1 Post By Rhapsody-NS27
  • 2 Post By geronimotwo
post #1 of 6 Old 09-18-2017 Thread Starter
Exclamation columbia 34mkII fuel tank replacement
the 47 yo fuel tank has rusted out for our Columbia 34mkII. are there any replacement tanks available? is there a reliable way of repairing this one? the tank is located under the starboard settee and although the top profile is a rectangle, the height is tapered like a wedge to fit the hull. the general dimensions are 24" fore to aft, 34-1/2" from port to starboard. not counting the 4 top mounted fittings the height is tapered from 12" on the port side to 9" (at 23-1/4" to strbd) , and 3-3/4" (at the strbd end) it may be possible to go an inch or two taller if needed. although I have appreciated having the 300 mile range that this 30 gallon tank has given me, I would consider a smaller alternative, ie a rectangular tank 24x24 and 10" tall would work for me as well. repairing this tank would be difficult as it is spot welded and soldered with an internal baffle. we are planning on heading south with her by November, so any links to a replacement are appreciated!
geronimotwo is offline
post #2 of 6 Old 09-18-2017
Daniel - Norsea 27
Rhapsody-NS27's Avatar
Re: columbia 34mkII fuel tank replacement
I wouldn't consider repairing since it's already compromised. The effort would likely be best served to replace it. If you're able to get it out of the boat in one piece, you could try finding a fabricator who can look at the old one to make a new one to the same size/shape.
geronimotwo likes this.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is online now
post #3 of 6 Old 09-18-2017 Thread Starter
we were able to get it out. no easy task, lol!
post #4 of 6 Old 09-18-2017
You might consider a fuel bladder.
www.fuelsafe.com
chriskiss is offline
post #5 of 6 Old 09-18-2017
Looks like a real task.
Did you source a replacement tank?
RegisteredUser is online now
post #6 of 6 Old 09-18-2017
If you can geter out, you can get the replacement in. Find a decent shop to copy in aluminium .I fold around the baffle, weld in the ends install all the fittings and refit. Watch for moisture problems where it sits and under straps. Pretty standard stuff.
Capt Len is online now
Tags
[email protected]
Columbia 34-2 fuel tank material bigchump Columbia & Coronado 17 09-18-2017 05:56 AM
fuel tank replacement on PS 25 [email protected] Pacific Seacraft 7 05-31-2017 04:46 PM
Here is our 1970 Columbia 34MKII 1970Columbia34 Columbia & Coronado 8 02-13-2011 06:19 PM
fuel tank replacement MIKEMCKEE Gear & Maintenance 21 10-05-2008 07:39 PM
Fuel tank Replacement samchristo Pacific Seacraft 3 08-06-2007 09:37 PM
HTML code is Off
