Columbia 23T vs. Coronado 23-2 different displacements, mainsheeting - SailNet Community
post #1 of 6 Old 11-18-2018 Thread Starter
On sailboatdata.com, the Columbia 23T is listed as having a displacement of 2300 lbs. The Coronado 23-2 is listed at 2500 lbs.
All references to these two boats say that they are identical except for the windows and coach roof.
Is there indeed a 200 lb difference in displacement?
Also, the mainsheeting systems appear different. The Columbia 23T has mid-boom sheeting going down to the sliding hatch cover.
On my Coronado 23-2, the mainsheeting goes down to a cockpit floor traveler.
I have the Columbia 23T manual but not the Coronado 23-2 manual... however, just about everywhere I read it is said that the two boats are the same.
Can any owners of either Columbia 23T or Coronado 23-2 speak on any of these issues?
Many thanks.
Hal Nash
Waldport OR
hnash53 is offline
post #2 of 6 Old 11-18-2018
Administrator
Jeff_H's Avatar
Re: Columbia 23T vs. Coronado 23-2 different displacements, mainsheeting
The Columbia 23T was a pretty strange boat that had an excessively wide keel with a very wide bottom and very shallow draft. The intent was that the cabin sole was in the keel sump in order to give the cabin a little more head room. They we're also supposed to be able to stand up on their keel bottom if they dried out when the tide went out. But they sailed really poorly.
If remember right, the Coronado 23-2 had it's keel redesigned to be slightly deeper and narroer and cut away a little more than the Columbia version. But the Columbias were slightly better built and so easily could have been a couple hundred pounds lighter.
I also think that the Coronado came standard with the Columbia's optional tall rig. The Columbia did not come with a traveler. There was a triangle 4:1 mainsheet with a block in each side of the tiller. I think that the Coronado had the mainsheet at the forward end of the cockpit.
Jeff_H is online now
post #3 of 6 Old 11-18-2018
As far as I have seen the Columbia T23 (AKA 23T Ranger) at 2,300 lb has a keel with centerboard that drafts 1.08 ft to 7.92 ft however the Coronado 23-2 at 2,500 lb has a fin keel w/transom hung rudder that drafts 1.92 ft and while very similar are not identical especially below the water line.
https://sailboatdata.com/sailboat/columbia-t-23
https://sailboatdata.com/sailboat/coronado-23-2
SeaStar58 is offline
post #4 of 6 Old 11-19-2018 Thread Starter
Thank you for the reply. I think that you mean the Charger 23 rather than the Ranger 23. You mentioned the draft as being 1.08 - 7.92. The 7.92 is rather the beam of the boat. And 1.08' is 13 inches... so I don't think that's accurate.
Coronado also made a Coronado 23... which is a Columbia 22 which has the fin keel with a 3.17 foot draft. Maybe you are thinking of this boat.
Both you and Jeff mentioned the keel shape as being different in the Coronado 23-2 from the Columbia 23T. However, in looking at owner pictures of their Coronado 23-2s, the keel looks to be identical to the Columbia 23T.
Thank you both for replies to my inquiries.
hnash53 is offline
post #5 of 6 Old 11-19-2018
Administrator
Jeff_H's Avatar
One thing that I probably should have noted is that I think that the later produced Columbia T-23's came with the same keels as the Coronado 23-2's. That original keel just was not a very good design in terms of sailing ability and I believe that the deeper-skinner keel with the aft end notched was adopted later in the production process, but I may be remembering this incorrectly. The one way to know is that the original T-23's had a piece of plywood and carpet right on top of the ballast keel down in the sump. The Coronados and I believe the later T-23's had the deck up where the hull turned down into the keel sump.
You can see the deeper keel reflected in the difference in draft between the two shown in SeaStar's Sailboatdata links.
post #6 of 6 Old 11-19-2018
They indicated it was 1.08 with the centerboard up though the board down numbers do seem excessive and yes match the beam. The version without the center board was claimed to be 1.11 ft draft which is indeed a very skinny shoal keel. The Coronado fin keel at almost 2 ft is a bit more conventional and yes I believe would perform much better than the skinny 1.11.
They appear to have made a number of variations on this design between the two companies and the various corporations that owned them through the years so I will believe that any variation on the basic theme is possible.
Columbia 23T vs. Coronado 23-2 displacement hnash53 Columbia & Coronado 1 09-10-2017 11:29 AM
Badly need Coronado 23-2 or Columbia 23 Owners Manual judgeyoung Columbia & Coronado 2 07-14-2016 05:49 PM
WANTED: Sails for Columbia 23 T, or Coronado 23 MkII juliancifuentes Columbia & Coronado 1 07-12-2012 11:01 AM
Need Performance Info: Catalina 22 vs Columbia 23T Soundtrackzz Boat Review and Purchase Forum 7 06-07-2012 06:08 AM
1974 Columbia 23T mast crusinman2002 Gear & Maintenance 1 08-15-2011 04:18 AM
HTML code is Off
