Dismasted/1964 Challenger - Page 3 - SailNet Community
 10Likes
post #21 of 44 Old 04-19-2019 Thread Starter
1964 Columbia Challenger
Re: Dismasted/1964 Challenger
While on chain plates- I will be pulling mine this Sunday and may need some advice, after. If they are trash and I need to fabricate anew- anybody setup double lower shrouds on this boat?
Any suggestions on spreader rake for the new CF mast?
More, soon.
Huff
Huffboat is offline
post #22 of 44 Old 04-24-2019 Thread Starter
Was only able to get the port side chain plate out and either it has been replaced in the recent past or it was done right in 1964. It is is pretty durn good condition, all in all. Very stout design. I suspect I will be able to un-bend it and re-use.
Am also hammering out the last design details for the mast. I will be replacing the boom with a Dwyer section. Closet to original is the DM 275 (2.75 inch tall, 1.75 wide) and the mast fabber is suggesting DM 375 (3.75 tall 2.25 wide)- do I need that much boom? I have not had any structural problems with the smaller section and if I don't need to add the weight and, more so, the added height (boom to head) I would be happy spending a little less money, too. The upside, maybe is that there is a heavier-duty gooseneck assembly that goes with it.
Thots on boom sizing?
Thanks, Huff
Huffboat is offline
post #23 of 44 Old 04-25-2019
overbored's Avatar
The challenger has end boom sheeting so there is not much load on the boom itself. change the sail to loose foot and then the load is even less, only compression loads. it worked before why won't it still work
"GOLD RUSH" PRINDLE 16
overbored is online now
post #24 of 44 Old 05-03-2019 Thread Starter
Ended up with the slightly larger boom profile as the next size down was smaller than original.
Was able to extract the other chain plate- stbd side was not easy to come out as the opening thru the deck was tight and wet. Bulkhead(s) are okay and deck looks okay. A PO had reworked an FRP beam athwarthships under the mast that is doing well, from initial inspection, but I have yet to yank off the mast step. I am having a new pair of chain plates made from a local water-jet cutter (approx $150).
CF mast goes into fab next week and should be arriving in one long package 4 to 6 weeks, after.
Am thinking about bringing the spreaders/shrouds inboard a bit. Original spars are approx 38 inches long, each, including the mast mounting bracket. As the CF mast will be stiffer and need a bit less "staying" I was thinking about coming inboard maybe 3 to 6 inches each spreader. Thots? New spreaders will be airfoil type and not nearly as substantial as the factory pipes (yeesh, one could fend off Huns with one of these- I kept one to use as a cheater pipe/hammer/lever).
Will post pics, later when pieces start coming to one place.
Thanks, Huff
Huffboat is offline
post #25 of 44 Old 05-03-2019 Thread Starter
...while on spreaders- I am also thinking about 3-5 degrees aft rake, just enough to keep a bit of positive tension for and aft. Thots? Thanks, Huff
Huffboat is offline
post #26 of 44 Old 05-04-2019
roverhi's Avatar
Who is making the mast for you?? The mast on my Sabre has some corrosion around the base and a crack so fear it's on borrowed time. Got one preliminary quote for a Carbon stick but it was more than twice what the boat is worth. Another company gave me a quote for the bare pole and some indication of costs to get it finished that were much more affordable but still more than I'd like to spend.
Don't see an advantage in raking the spreaders, Fore and aft mast support is provided by the head and back stay. Raked spreaders, even a little bit, restrict how far you can ease out the boom before the sail hits the wires and spreader. On my boats with right angle spreaders it's been the aft lowers that hit the sail first. Would try and eliminate the aft lowers if you boat has them and leave the spreaders at right angles. You could rake the spreaders far enough to eliminate the backstay but that will really restrict how far you can let the boom out. Not a big thing on a multihull as they sail faster reaching downwind but on a mono will affect DDW performance.
roverhi is online now
post #27 of 44 Old 05-04-2019 Thread Starter
Mast, so far, including shipping from CT to CA is approx $5K, from Forte.
I may very well shorten the spreaders some inches, tho, each, to bring inboard a bit if I don't have to "stay" as much mast weight with the shrouds.
Thanks,
Huff
Huffboat is offline
The Following User Says Thank You to Huffboat For This Useful Post:
roverhi (05-11-2019)
post #28 of 44 Old 05-09-2019 Thread Starter
Anyone have a good spreadsheet for figuring out dimensions of standing rigging? I can't really use the "factory" specs/data and need to start from scratch as the rig is now semi-fractional and some other sizes have changed, as well, with the new custom mast. I have gone back to reg 'ol geometry for most of this, which could well work (trapezoids, triangles) but am hoping to have a way to double-check. Thanks, Huff
Huffboat is offline
post #29 of 44 Old 07-31-2019 Thread Starter
Thumbs up Re: Dismasted/1964 Challenger
Update: Mast is here (pic attached) and is approx 60- 65% weight of the aluminum (I haven't weighed it, yet, but just going by feel). I have taken the dimensions (is nearly same height and section/profile size as original), and am now figuring standing rigging.
New sails should be here in a week, and hope to step the mast in 2.
Will post as to progress and sea trials. Huff
Minnesail likes this.
Huffboat is offline
post #30 of 44 Old 07-31-2019
Administrator
Jeff_H's Avatar
Several quick points:
If you are going to a slightly fractional with your rig, you will want to go with slightly aft swept spreaders and slightly aft set uppers and lowers. If you sweep the spreader aft you can eliminate the forward lowers and the lowers do not need to be set aft as far as they will need to be if there are forward lowers.
I do want to correct the misstatement above. actually the mainsail can be eased further with swept aft spreaders because the lowers are further forward than they would be with be without fore and aft lowers.
But beyond that, in order to take advantage of the virtues of a fractional rig, simpler rigging and the ability to quickly depower the rig, you either need swept back spreaders, or running backstays.
Jeff_H is online now
1969 MacGregor Venture vs 1964 Islander Bahama 24 Sailboat101 Boat Review and Purchase Forum 13 09-15-2010 12:43 PM
Is a Fibreglass boat built in 1964 at the end of it's life? lrak Gear & Maintenance 11 08-30-2009 02:02 PM
1964 24'' American Marine (Grand Banks) Blackhole.Net General Discussion (sailing related) 0 01-31-2001 07:48 PM
HTML code is Off
