Loose Wincher - SailNet Community
post #1 of 6 Old 11-23-2019 Thread Starter
1964 Columbia Challenger
Loose Wincher
Don't get any notions, boys- this is a family show.
My "small" Wincher self-tailing converters are loose on my Lewmar 6 winches. Fabber wrote back saying it needs "packing of some sort".
I am pretty sure that I am not the only one this has happened to- I would guess that these rubbery Winchers are either too tight or too loose, on a regular basis.
I am thinking about just filling (1/16th inch?) void w/5200 and be done with it.
Any other suggestions?
Thanks,
Huff
Huffboat is offline
post #2 of 6 Old 11-23-2019
Re: Loose Wincher
Self vulcanising high volt electricians tape ?
Capt Len is online now
post #3 of 6 Old 11-23-2019 Thread Starter
Re: Loose Wincher
You do bring up a good possibility, though- self-bonding riggers tape might work.
Huffboat is offline
post #4 of 6 Old 11-23-2019
Master Mariner
capta's Avatar
Re: Loose Wincher
I'd be real careful about using 5200 indiscriminately. If it doesn't work the clean up could be nearly impossible. 5200 is not a product to be used unless you know exactly what you are doing and never, ever expect to have to remove what you have glued down with it.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #5 of 6 Old 11-23-2019
pdqaltair's Avatar
Re: Loose Wincher
I'd try athletic tape. Good friction, conforms well, will not slide.
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
post #6 of 6 Old 11-23-2019
Re: Loose Wincher
Yeah, cheap try. Layer as needed until built up tight.
Skip the 5200
Used to be able to get friction tape...
Slice and apply non skid tape and youd be golden. Dont use nice scissors..
RegisteredUser is online now
HTML code is Off
