generator a good idea? - Page 2 - SailNet Community
 82Likes
post #11 of 92 Old 09-16-2014
islander bahama 24
newhaul's Avatar
Re: generator a good idea?
Dave get the generator you will likely need it this winter we are supposed to have a bad one for the boat I recommend a solar panel like this 60W Monocrystalline Solar Panel | Renogy Store with no refer but this Mono Starter Kit 100w | Renogy Store with refe
Illegitimus Non Tatum Carborundum.
newhaul is offline
post #12 of 92 Old 09-16-2014
If you have a diesel engine, would you really want to have to store gasoline on board?
cruisingdream is offline
post #13 of 92 Old 09-16-2014
travlin-easy's Avatar
The big question is "Do you need 110-volts AC? And, if so, why?" If you do not absolutely need 110-volts AC, there is no reason to have a Honda or any other brand of generator. However, if you have a heat pump on your boat, then that Honda will come in real handy on those hot, humid nights when anchored in the Bahamas or Florida Keys. AC, especially for me, is not a must at this point, but I'm getting a lot closer to needing it for medical reasons. My lungs are shot to Hell from asbestos, therefore, on those hot, humid nights the AC will lower the relative humidity and temperature, make the air more dense, and make my blood oxygen level increase by a few percent, which can be vital in my case.
Now, if you're a youngster, like Jon, then you can tolerate the heat and humidity.
Good luck,
Gary
travlin-easy is online now
post #14 of 92 Old 09-16-2014
islander bahama 24
newhaul's Avatar
Gary Dave is in the Puget sound in pnw more likely need heat than ac
newhaul is offline
post #15 of 92 Old 09-17-2014
Bill SV Rangatira
Bill-Rangatira's Avatar
Send a message via Skype™ to Bill-Rangatira
I'm in PNW area but a bit north and my heat is a bulkhead heater
Bill-Rangatira is offline
post #16 of 92 Old 09-17-2014
Think about it this way, there are a thousand bareboats in the BVIs and none (nearly none) have generators and their crews are usually off the dock for a week at a time.
Unless you absolutely have a need for 110v power, making 12v isn't all that hard. As pointed out, you run the engine at a slightly increased RPM, in neutral, for about 90 mins per day and you should be all set. If you motored for that amount of time, you're already done.
That's assuming your house bank is sized properly to get you through at least the day, if not two or more. If you're willing to spend money on a genset, spend it first to be sure your house bank is big enough.
You're going to love waking up at anchor!!
Jeanneau 54DS
Minnewaska is offline
post #17 of 92 Old 09-17-2014
bljones's Avatar
Originally Posted by Dave_E View Post
Hi Cruisers,
It has been suggested by a few of my power boat buddies to just get one of those tiny Honda generators.
Dave
It's funny how when your only tool is a hammer, you think of every problem as a nail. Powerboaters always think the only choice is a generator.
Sailors largely go solar and wind generation first.
We have 80 watts of solar power aboard, soon to be 120 watts, no shorepower, and although we own a generator, have never had to use it on the Dock or on the hook- our generator is only used in the boatyard.
the solar was a lot cheaper than a generator, btw.
T37Chef, RickWestlake and Ajax_MD like this.
It's 5 o'clock somewhere:
bljones is offline
post #18 of 92 Old 09-17-2014
smj
The worst thing you can do to your diesel primary propulsion engine is to use it to charge your batteries. The engine doesn't have enough load on it to reach optimum temperature and it will age your diesel quickly.
Solar and wind are great ways to keep the battery topped up but sometimes the sun don't shine and the wind don't blow, that's where the Honda generator comes into play. The Honda 2000 will run a 110v 100 amp battery charger. It will also heat enough water for two showers in about 15-20 minutes. Also great if you want to use power tools and it is pull start so if the batteries are dead no worries!
All this for $999.00 free shipping from Mayberrys. Not everyone's cup of tea, but for full time cruising it makes sense to me.
smj is offline
post #19 of 92 Old 09-17-2014
TQA
Bombay Explorer 44
TQA's Avatar
Originally Posted by Delezynski View Post
Dave,
On our boat we have refrigeration, nav stuff, VHF, SSB, HAM radios, lights, computers and other items. We have a 300 Ah house battery bank. In 2000, I DID add solar power at a much higher cost than it is now.
We departed for full time cruising in 2004 and returned to the US in late 2008. This past year (AND the year before) we cruised full time for almost 6 months with one (1) 85 watt solar panel with no problems.
IN ALL THAT TIME we NEVER had, or needed a generator!
A small solar panel & controller would be FAR less $ than a generator and also not bugg your neighbors at anchor!
Greg
WOW DOUBLE WOW
Running a fridge on an 85 watt panel. Which fridge is it? I need one!
TQA is offline
The Following User Says Thank You to TQA For This Useful Post:
miatapaul (09-18-2014)
post #20 of 92 Old 09-17-2014
Old soul
MikeOReilly's Avatar
I bought a Yamaha 1000w generator 10+ years ago. It's been used on the boat maybe eight times to charge batteries, and seven of those times was when we took off and didn't realize our old Airx wind generator had packed it in. Used it on that trip.
Wind (Silentwind generator) and 100 watts solar keep us fairly well off. I'm adding another 100 or so watts.
The Yamaha is a nice safety blanket. It sits in my sail locker, and almost never gets used. If I had the spare $1000 I'd spend it on solar panels, not a new generator. Or but Delezynski's fridge! That's astounding.
Why go fast, when you can go slow
Why go fast, when you can go slow.
BLOG:
MikeOReilly is online now
Seemed Like a Good Idea... Squidd Gear & Maintenance 11 04-09-2012 07:42 PM
Soft shackles a good idea? tenuki Gear & Maintenance 60 02-22-2012 03:48 AM
Who thought this was a good idea? flyingwelshman General Discussion (sailing related) 14 04-08-2010 07:19 AM
a good food idea Tegolin Provisioning 1 06-25-2005 07:47 PM
