looking for advice on sailing north FL to MA - SailNet Community
post #1 of 6 Old 12-28-2014 Thread Starter
i am sailing a 25 ft 1969 coranado fin keel with a 3.6 draft and a 9.9 johnston outboard 2 stroke. im looking to leave fernandina beach , florida in or around april 2015 to the inside of the hook of massachusetts. any advice for a beginer sailor?
i know i have to go on the inside at cape hatteras.
- is there any other places i should go around or avoid?
- some people say i cant do it in my little boat with my little engine?
- what is your opinion on the sailboat i am taking?
i will have a portable vhf, and a portable garmin gps. i have the icw flip book chart, and good ground tackle. sails are in good condition. not much of an electrical system. i have a depth finder and a compass, but i dont use much else than that. i want to sail outside as much as possible and was just planning each passage by the weather. any advice helps.
thanks
Tankvictorian is offline
post #2 of 6 Old 12-28-2014
FSMike's Avatar
Re: looking for advice on sailing north FL to MA
You can do it if the boat's in good condition and you pay close attention to the weather.
However - if you are going by yourself I greatly recommend an autopilot and enough of an electrical system to deal with it.
If you plan on going in and out of inlets every day to anchor up, be aware that a lot of inlets involve traveling a good distance to find an anchorage. That can make for a long day. Fernandina Beach to St. Simons Sound can take longer than you think, anchor up to anchor down.
Got a liferaft or a dink with positive flotation in case of disaster?
Charts that show the class A inlets?
Be all that as it may, you can do it. Have a good time.
Sail Fast Live Slow
36' Solaris Sunstar catamaran
FSMike is offline
post #3 of 6 Old 12-28-2014 Thread Starter
thanks-
i usually just anchor anywhere out of the way of channels and other boats. i dont usually travel that much farther than where i pull in.
i have a kayak as a dinghy that i use to get back and forth.
post #4 of 6 Old 12-28-2014
Originally Posted by Tankvictorian View Post
thanks-
Usually, as in where? This just isn't always a possibility.
With your draft, you should plan to take advantage of the ICW as much as you can. It's an experience your grandchildren may not have, as maintenance is being cut for many stretches. You'll get in plenty of sailing to get around New Jersey, up Long Island Sound, Block Island Sound, Buzzards Bay and Cape Cod Bay
Jeanneau 54DS
Minnewaska is offline
post #5 of 6 Old 12-28-2014 Thread Starter
yes i have been ocean sailing down the coast of maine- then sc to northern fl.orida i preffed the ocean over the icw. the icw cost alot more money. im a poor sailor
post #6 of 6 Old 12-28-2014
Will you have any crew for this voyage?
Jeanneau 54DS
Crew Wanted North Carolina to points north 4/23/14 into summer JohnZion Crew Wanted/Available 6 04-21-2014 09:44 PM
Crew Wanted North Carolina to points north 4/23/14 into summer JohnZion Crew Wanted/Available 0 04-17-2014 08:12 PM
Advice Sailing North West Atlantic Coast (U.S.) North Carolina to NYC White Beard Destinations 5 05-05-2013 10:49 PM
USWatercraft LLC Snags Alerion Yachts, True North and North Rip Tanley General Discussion (sailing related) 0 12-17-2012 05:55 PM
Sailing Companion/ North River/ Mobjack - day sailing. CSmall13 Crew Wanted/Available 0 09-06-2010 11:49 AM
