Cruiser versus motor sailer - Page 4 - SailNet Community
 9Likes
post #31 of 39 Old 03-01-2016
Guest
Re: Cruiser versus motor sailer
Originally Posted by cshrimpt View Post
Take a look at the Nauticat motorsailers. Pretty roomy and robustly built. They are pilothouse boats so make sure you never get rolled. I.e., series drogue.
I'm not sure what is meant by this advice. A pilothouse will have far more righting ability when rolled than a boat without a pilothouse. Maybe you are referring to the sliding side doors on the Nauticat motorsailers. Just keep the doors closed (and secured).
Periwinkle
Boat for sale ad removed per forum rules- Jeff_H SailNet moderator
S/VPeriwinkle is offline
post #32 of 39 Old 03-01-2016
Cruisin' for a Bruisin'
I read a first hand account where a Nauticat was rolled by a wave and the windows blew out. It did right itself and everyone was fine. In any case, pilothouse or not, avoiding capsize is good advice for everyone!
Craig
S/V Wayfinder - 1985 Pacific Seacraft 34
cshrimpt is offline
post #33 of 39 Old 03-01-2016
Guest
Craig
Ah, I see your point. Yes, if the pilothouse doesn't remain (more or less) water-tight, it doesn't help at all! Bullet-proof windows, and of course strong frames, are essential. I had assumed that Nauticats met this requirement. Maybe some do and some don't depending on when they were built and/or what the original owner ordered.
Of course the same applies to other boats without pilot houses. Many boats have incredibly flimsy, and incredibly large, ports and especially hatches. A breaking wave would take those out easily.
Periwinkle
post #34 of 39 Old 03-01-2016
Master Mariner
capta's Avatar
Craig
Prudent seamanship would dictate that if one is going offshore in a vessel with windows such as the pilothouse windows on a Nauticat, one would have storm boards for those windows.
Way back before Lexan, we covered our pilothouse windows with plywood on the Northern Trollers when the weather got up off the West Coast (remember in "The Perfect Storm" them trying to put up their storm boards?).
If you are taking ANY vessel with large windows to sea without proper storm boards, you really have no right to ask others to risk THEIR lives to rescue you, if you get in trouble because of it.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #35 of 39 Old 03-02-2016
Does anyone have examples of how storm boards have been affixed to port lights?
Jeanneau 54DS
Minnewaska is offline
post #36 of 39 Old 03-02-2016
Master Mariner
capta's Avatar
Normally they are secured by carriage bolts inserted from the inside of the boat through the cabin side (sealed and waterproof) at the corners and secured with a nut on the outside, with some threads sticking out for the storm boards. The storm boards are placed on these bolts and secured with either wing nuts w/lock washers or lock nuts when offshore. The threaded ends are covered with cap nuts when not in use. These days Lexan (because you can see through them) makes a good storm board and for the last set I put on an 80 footer I used 3/4", but plywood would do the job equally well with a small (4" x 6") viewing port cut to see out of, and MUCH cheaper.
On steel boat there is usually a channel welded around the window which the storm boards slide into and they are held in place by set screws.
capta is online now
post #37 of 39 Old 03-02-2016
Found this example on-line image:
Faster is offline
post #38 of 39 Old 03-02-2016
Closet Powerboater
MedSailor's Avatar
I would want to epoxy in threaded inserts, as it appears was done in this photo. In addition, there appears to be a generous lip/edge which would help spread a compression load from a wave over a larger area of fiberglass.
MedSailor
MedSailor is offline
post #39 of 39 Old 03-02-2016
Pretty ugly to have the attach points exposed, after the boards are removed at destination. Price to pay, I suppose.
Jeanneau 54DS
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
mcsmith
Nauticat 33 motor sailer KlausS SailNet FAQ 1 03-16-2014 07:41 PM
44' Gulfstar Motor sailer Bayduk Introduce Yourself 9 01-24-2013 01:35 PM
Would you buy a Columbia 45 Motor Sailer C45JCM Boat Review and Purchase Forum 0 10-08-2006 01:15 PM
La Paz 25 Motor Sailer katakolo Boat Review and Purchase Forum 0 06-25-2006 03:53 AM
La Paz 25 Motor Sailer katakolo General Discussion (sailing related) 0 06-25-2006 03:44 AM
