Coming from RV to boats. Do you use holding tank chemicals? - SailNet Community
 4Likes
post #1 of 35 Old 06-22-2016 Thread Starter
In my RV's I use holding tank chemicals. Either enzyme based to digest and break down waste or stuff to keep it from smelling. I'll be full time liveaboard, and plan to pump 1-2 times per month. I'll avoid solid waste, but it will happen in the middle of the nights I predict.
Do you use chemicals or what controls order and breakdown of TP and waste?
1988 C&C 30MkII used as a live aboard in MD. Sailing experience: Started 2014; 6-mo on Hobbie Cat Wave 13', 1 year on a Potter P15 sailboat, and ASA 101,103/104 classes. Power boater for 20+ years.
serpa4 is offline
post #2 of 35 Old 06-22-2016
Lake Superior Sailor's Avatar
Re: Coming from RV to boats. Do you use holding tank chemicals?
Same as the camper!....Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #3 of 35 Old 06-22-2016
Yup, but there's still plenty of stuff that doesn't work. I'm a fan of Happy Campers:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
IStream is offline
post #4 of 35 Old 06-22-2016
Learning the HARD way...
eherlihy's Avatar
Many people swear by K.O....
I use SeaLand Holding Tank Deodorant;
mbianka likes this.
USCG Licensed OUPV Captain, ASA 101/103/104/105/106/114/118 Instructor - Also certified in Marine Electrical Systems
eherlihy is online now
post #5 of 35 Old 06-22-2016
Stu Jackson's Avatar
The New Get Rid of Boat Odors
KO or Odorlos
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #6 of 35 Old 06-23-2016
snake charmer, cat herder
zeehag's Avatar
Send a message via Yahoo to zeehag Send a message via Skype™ to zeehag
odorlos.
best stuff on planet
donot put tp into your holding tank unless you want a foul mess. bag it
formosa 41, cruising tropics
zeehag is online now
post #7 of 35 Old 06-24-2016
I'd rather have a foul mess in my tank than in bags out where I can see/smell them.
IStream is offline
post #8 of 35 Old 06-24-2016
pdqaltair's Avatar
Just as much fun as an anchor thread, but smellier!
1. There is a no-TP cult. If that is too gross for you, the trick is to make certain to use single ply (Scott is best in testing) and flush enough water to keep liquid.
2. Do NOT use the blue deodorizing chemicals. They don't work and are bad for the hoses. Do use something containing nitrate, like Oderlos. The enzyme treatments seem to work too.
3. Flush the vent once in a while. They tend to plug with c__p due to healing and too full tanks.
4. Post a sign in the head for guests saying what not to flush and how to operate.
Minnewaska and MarcStAug like this.
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #9 of 35 Old 06-26-2016
travlin-easy's Avatar
I used Rid-X while in the Florida keys and it seemed to do a great job. Doesn't take very much when your holding tank is just 30 gallons.
I agree on flushing or cleaning the vents regularly. In my case, mud daubers decided it would be a great place to call home and packed it solid with mud. I then found a new fitting that had a screen so they couldn't get into the hose and fitting - they still packed the damned thing, only this time, on the outside edge of the screen. Finally, I put a few drops of Avon Skin So Soft on the screen and they stayed away.
If your vent gets clogged, you could end up with a collapsed holding tank during pump-out. The pump-out boats in the Florida Keys had very powerful, gasoline engines that ran the vacuum pumps, which could easily collapse a quality stainless holding tank in a matter of seconds.
Play it safe,
Gary
travlin-easy is offline
post #10 of 35 Old 06-26-2016
pdqaltair's Avatar
I tested a lot of these side-by-side using a row of matching holding tanks for Practical Sailor. Sealand, as I recall, finished dead last. You can do better with other forum suggestions, I promise. This one is also rough on hoses.
Ridex also did poorly, is rated poor by everyone, and is not recommended for this purpose by the maker. There are better products.
Holding tank Beach bum Gear & Maintenance 2 01-06-2014 09:37 AM
O/I 41 holding tank tatoloco Morgan 4 02-01-2011 11:50 AM
Convert existing steel freshwater tank to blackwater holding tank? patrickstickler General Discussion (sailing related) 7 09-24-2010 07:55 PM
Holding Tank cvsheppard Pacific Seacraft 1 06-01-2009 10:27 PM
Holding Tank Scubado Gear & Maintenance 14 04-01-2004 11:24 AM
