Planning a Topside Washdown System - SailNet Community
 14Likes
post #1 of 41 Old 12-17-2016 Thread Starter
Goal:
Pressure seawater for deck washing, anchor washing, personal washing, fish guts, etc....just pressurized raw water for general use up top.
My initial thoughts are to mount a pump in the lazzerette, minimize wiring runs and not put any new fixed plumbing into the boat.
Use 50' coil 1/2 or 5/8 hose and something like an 8' suction hose that would be thrown over the side.
The boat is 34' so that 50' coil hose might be at its limit...
Convenience and ease of use is important. My thinking...I can flip the lid in the cockpit, attach 2 hoses that are well-stored nearby, flip the switch, and then go to town...
Lazz drains to bilge so that's covered.
The boat has a windlass so big wire is already there, but I really don't want to add any thru deck fittings or in-cabin plumbing. Yeah, a 15' coil would be less of a pain than a 50'.
The 'kits' have some things I don't think I'll need, so I'm thinking just a pump and then lawn and garden items...
I would appreciate hearing past successes and failures in this department, and anything I missed in planning this.
Thx in advance.
RegisteredUser is online now
post #2 of 41 Old 12-17-2016
Dock
Re: Planning a Topside Washdown System
The PO on my boat (Alberg 35) made one based on the thru hull for what was in the past the intake for the head (with seacock). There is a simple pump and switch below in the head, line running to a deck fitting, where we connect a hose. I sail in the Chesapeake and it does a great job of washing mud off the anchor and chain; never used it for actually cleaning the boat as we are based in a marina and have access to water there. No reason it couldn't be used to rinse the deck. The only modification I would make if I could or wanted a project is a way to activate the switch from above. I seem to forget it and end up making an extra trip below. Works great though.
Pendragon35 is offline
post #3 of 41 Old 12-17-2016
Tapping into an existing thru-hull intake would be more convenient. Household spray heads and fittings, rust out very quickly in salt water.
Jeanneau 54DS
Minnewaska is offline
post #4 of 41 Old 12-17-2016
travlin-easy's Avatar
My saltwater washdown pump is in the head, attached to a "Y" fitting, one that is the inlet to the head and the other for the washdown pump. Works great, I have just a 25 foot, coiled hose, which I primarily use for washing the mud and crud from the anchor and chain as I winch it in. I wash the decks with the same hose and pump, but it's by no means a power wash, just a rinse down after I hit the decks with a scrub brush and cleanser.
Good luck,
Gary
travlin-easy is offline
post #5 of 41 Old 12-18-2016
TakeFive's Avatar
Originally Posted by RegisteredUser View Post
...My initial thoughts are to mount a pump in the lazzerette, minimize wiring runs and not put any new fixed plumbing into the boat.
Use 50' coil 1/2 or 5/8 hose and something like an 8' suction hose that would be thrown over the side...
What kind of pump? A centrifugal pump has no suction, so you won't get anything through the hose. (That's why everyone puts centrifugal pumps right next to the through-hull.) A diaphragm pump has some suction, but probably not enough to pull the air volume of an 8' hose, and it will be pulsating. A positive displacement impeller pump might do it, but won't be cheap and might not be high enough volume.
Here's the solution that I put together. I used it to wash down the anchor on my old 25' boat. I still have it, but generally just use a bucket tied to a rope that I dip down into the seawater. This pump might not provide as much volume as you want. But you can move it to anywhere on your boat, as long as you have a 12v outlet or portable battery nearby:
Rick S., Swarthmore, PA
USCG Certified Captain, OUPV and 50 Ton Master
2001 Catalina 34MkII Tall Rig Wing Keel Breakin' Away, Universal Diesel M35B, Mantus 35 lb. anchor, sailing out of Rock Hall Landing Marina
TakeFive is offline
post #6 of 41 Old 12-18-2016
Master Mariner
capta's Avatar
We have 4 of these pumps aboard. One makes the perfect non-installed washdown pump hung over the side and run off the inverter.
They are pretty handy as dewatering pumps (1550 GPH at 10 ft. of discharge lift each) run off the generator should the need arise. They can pump 1 1/4 inch discharge or they can use a garden hose with the included adapter.
SanderO likes this.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #7 of 41 Old 12-18-2016 Thread Starter
I like that.
A rope with a hook on the toe rail...
baywater likes this.
post #8 of 41 Old 12-18-2016
RichH's Avatar
What's the diameter of your head intake through-hull? It would be a very rare occurrence to be using the head while simultaneously washing the deck/anchor rode. Consider to hard pipe the intake to your salt water pump.
Also consider to add an 'as large as possible' accumulator to 'keep up' the system pressure during 'wash down events'; using as large as possible plumbing diameters to lessen flow restriction and pressure losses.
RichH is offline
post #9 of 41 Old 12-18-2016
Rich, my thru-hull fitting is 3/4-inch diameter. I cannot recall anyone using the head while I was washing down the anchor chain and anchor.
Gary
post #10 of 41 Old 12-18-2016
My dedicated wash down thru-hull is 3/4in. Can't see any issue with sharing one, as long only one device is drawing at a time.
Jeanneau 54DS
Washdown pump.... sailordave Gear & Maintenance 12 06-06-2012 12:18 PM
Anchor washdown system brokesailor Pacific Seacraft 23 04-21-2011 02:03 PM
washdown hose davidpm Gear & Maintenance 7 08-22-2009 10:21 PM
Washdown pump SailChick20 Gear & Maintenance 5 03-07-2009 11:42 AM
Good Planning and Bad Planning John Rousmaniere Seamanship Articles 0 10-11-2001 09:00 PM
