Welland canal transit - SailNet Community
 1Likes
post #1 of 16 Old 05-24-2017 Thread Starter
I'm hoping to transit the Welland Canal in about 2 weeks for the first time - Lake Erie to Lake Ontario. Someone told me recently that you need super long mooring lines - in the order of a hundred feet. Really? Surely that's a bit apocryphal? I have lots of good strong mooring lines aboard - but nothing like that. Or do I need to head for the chandlery?
Have any recreational boaters transited in the last little while? Any other tips? How are Port Dalhousie and Port Colbourne dealing with the high water?
dailymirror is offline
The Following User Says Thank You to dailymirror For This Useful Post:
timangiel (05-26-2017)
post #2 of 16 Old 05-24-2017
Dirt Free
boatpoker's Avatar
Re: Welland canal transit
Came through day before yesterday on my 100th passage.
No, you do not need any mooring lines. You will pull up near the front on the lock and they will drop two lines too you.
You must have three crew onboard for upbound passage one at bow, one at stern and a helmsman. This requirement is due to the extra turbulence when filling the locks, you do need someone on the throttle. Downbound you can do it single handed if you are good enough but I don't recommend it, two is best.
There are free docks at either end of the canal where there are phone booths with dedicated lines to check in with Seaway Control.
There are no service at either dock. When you come into the canal from Lake Ontario look for the first little basin on the port side and the telephone booth, you can tie up there.
What kind of boat ?
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
The Following User Says Thank You to boatpoker For This Useful Post:
dailymirror (05-24-2017)
post #3 of 16 Old 05-24-2017
Moderator
Arcb's Avatar
Nothing to add to BP's post except that it's correct. They'll provide approximately 100' poly pro lines. Minimum 3 adults on board.
Arcb is offline
The Following User Says Thank You to Arcb For This Useful Post:
post #4 of 16 Old 05-24-2017 Thread Starter
Thanks Boatpoker!
I'm planning on transiting the canal the week of June 5th. The boat is a CS33 with a 3YM20 motor. Crew will be my wife and I and a couple or three friends from Hamilton. Weather permitting.
post #5 of 16 Old 05-24-2017 Thread Starter
By the way, I'll have to read the Guide again, but I think I read recently that recreational boats can only start the trip between 9 AM and 5 PM. Is that accurate?
post #6 of 16 Old 05-24-2017
Moderator
Arcb's Avatar
Not sure about that. It used to be 24/7 until pretty recently. Maybe give them a call?
Could be a long night if you show up past 5, I've taken anywhere from 6-16 hours for a transit with 8-10 being normal.
Arcb is offline
dailymirror (05-25-2017)
post #7 of 16 Old 05-24-2017
Dirt Free
boatpoker's Avatar
24/7 for all vessels. It took us 7hrs downbound the other day. My average is about 10hrs. 12-14hrs is not all that unusual but I have taken as long as 36hrs when they shut it down with me in lock 3 due to fog...... a very long night.
Arcb likes this.
post #8 of 16 Old 05-24-2017
Went upbound exactly one year ago. Checked in at 7 am, started moving 4pm, finished 1am. I think it is a bit cheaper if you pay toll online.
Sent from my SM-T580 using Tapatalk
skalashn is online now
The Following User Says Thank You to skalashn For This Useful Post:
post #9 of 16 Old 05-25-2017 Thread Starter
Hmmm. So, extra snacks. And if we're not close friends when we start we may be by the time we're done!
post #10 of 16 Old 05-25-2017
Dirt Free
boatpoker's Avatar
If you don't kill each other first
PS. When we went through the other day the credit card machine at the phone booth was down .... no charge for canal transit. Get there before they fix it.
Welland Canal down bound advice MikeOReilly Seamanship & Navigation 23 09-09-2014 12:26 PM
Welland Canal Canada. Advise needed (perhaps legal) fparry General Discussion (sailing related) 7 06-13-2010 08:08 PM
Hay Bails and the Welland Canal fparry General Discussion (sailing related) 10 05-26-2010 03:40 PM
Dock lines and other equipment for the Welland Canal fparry Gear & Maintenance 6 05-13-2010 10:14 PM
