Plex server - Page 4 - SailNet Community
 12Likes
post #31 of 42 Old 10-03-2018 Thread Starter
snokid's Avatar
Re: Plex server
Originally Posted by Caribbeachbum View Post
I added some other stuff. For example, I added a web service and have mirrored Wikipedia on the NAS, so I can look stuff up when no internet is available. I've been considering mirroring other web sites, but I think most might prefer that I do not. Noonsite came to mind ...
Basically, the NAS will my boat cloud server. A good NAS will do a lot while consuming little power and taking up very little space.
Wow that's a great idea will be doing that...
snokid is offline
post #32 of 42 Old 10-03-2018 Thread Starter
snokid's Avatar
Re: Plex server
Capta yes you are correct any distraction to your job on watch isn't ideal. I'm sorry I shouldn't of asked this question in that way.
I do feel however if I have a tablet running a movie or music (no headphones) isn't much of a hazard to navigation. I'm not saying one should stare at the screen, but if you look up and take note every 5 mins or so I don't see the big problem.
enuff said on that topic.
Bob
snokid is offline
post #33 of 42 Old 10-03-2018 Thread Starter
snokid's Avatar
Re: Plex server
OK now that those comments are taken care of....
I installed a NAS with plex on it. It's working just like I wanted it to.
For others that want to do this, couple of things I have figured out mostly the hard way!!!
Get the NAS/PLEX up and running at home first. You just don't buy a NAS and plop hard drives in it and have a plex server.
I was at the boat when I got this running very limited internet.
So if you are like me you have a laptop on board and you get wireless internet from a marina. That's all great and good, but how does the NAS get the internet to install the Plex software? How does your laptop talk to the nas?
so a least you are going to need the NAS and a router, now the NAS is wireless, part of the problem solved, you can now log into the NAS and set it up, but you can't install plex yet...
I don't know if this works with all laptops but here's what worked for me.
connect the laptop to the marina wifi, then connect the laptop to the router's internet in port (cat 5 cable) then in network settings I was able to bridge the connections... That gave the NAS the internet it needed to install plex.
now you can install plex on your devices.
So how I have this now(well as a couple of weeks ago, I'm off the boat for a few months now) I have a wifi router hooked to the NAS and if I want to watch something off it I just switch my wifi connection on my laptop to that router start up plex and presto I can watch.
What's not so documented is you have to pay for plex premium if you want to watch on your phone, tablet. Not at problem just saying it because I didn't know.
I did a qnap nas, I don't think brand so much matters from what I can tell.
ripping dvd's is time consuming and a whole new learning curve.
Bob
snokid is offline
post #34 of 42 Old 10-03-2018
MacBlaze's Avatar
Re: Plex server
So you've got to power what?
A NAS?
A laptop?
A router?
A tv/monitor?
Is everything running off 120 or have you converted some to 12v?
Gaudeamus igitur iuvenes dum sumus...
before it's too late
Youtube:
MacBlaze is online now
post #35 of 42 Old 10-03-2018 Thread Starter
snokid's Avatar
Re: Plex server
A NAS?
A laptop?
A router?
A tv/monitor?
As we are getting ready to sail away into the sunset
I only have so much time to spend upgrading the boat, right now yes everything is powered by 120v ac, but we only turn on the inverter when we are going to use those items.
I don't see any reason all of those items can't be run off 12v thou.
Bob
snokid is offline
post #36 of 42 Old 10-04-2018
Re: Plex server
A NAS?
A laptop?
A router?
A tv/monitor?
All that (and more) runs on the inverter. Nothing is powered up, though, except when it's in use.
Caribbeachbum is offline
post #37 of 42 Old 10-04-2018
Re: Plex server
Buy a Synology NAS box. Install the hard drives and connect it to your network (Ethernet or WiFi). No internet is required here, but it's nice to have. Enable Plex for video, iTunes server for audio. There are other cool toys as well. Copy your digital media to the NAS box. Make sure your media player is connected to the network. It's really, really simple. I have just been setting up a 12TB NAS for our new boat just for this purpose. iDevices will see the iTunes server; devices with a Plex client (Apple TV works) will see the Plex server. Enjoy your media.
I should I should update this ... Plex has a real taste for an internet connection. While we do have a network and WiFi, there is often no internet. So I dumped Plex. We use the Synology DSVideo and DSAudio apps instead. They are not as feature-rich, but they happily chug along on the local network without internet access. They are a bit speedier as well.
post #38 of 42 Old 10-05-2018
Re: Plex server
That's odd. Mine works just fine, net or no net.
IStream is offline
post #39 of 42 Old 10-06-2018
SanDiegoChip's Avatar
Re: Plex server
Hi,
At the risk of sounding naive, can you use a router and a WiFi tv and a laptop with WiFi but no carrier?
We like Plex because it is easy to say find a comedy to watch on our USB drive because it catalogs all the content. However we rarely have a WiFi signal good enough to stream especially at anchor.
Thanks,
Chip
s\v Elegant'sea Blog
SanDiegoChip is offline
post #40 of 42 Old 10-06-2018
Re: Plex server
Others have told me this as well. I don't doubt you. Once you have it all set up and configured, it's probably OK with no internet. But you will never get it up and running without an internet connection. Since it started out so net-greedy, I assumed it would continue that behavior.
polishing plex scosch Gear & Maintenance 23 03-07-2010 03:18 PM
Server is SLOW!!! CharlieCobra General Discussion (sailing related) 17 05-23-2008 11:42 AM
West Marine.. to server or not to serve sailboy21 General Discussion (sailing related) 3 12-14-2007 11:26 AM
Slow SailNet server? TrueBlue Announcements and Suggestions Box 3 05-16-2006 07:25 PM
Server down? skipgundlach General Discussion (sailing related) 0 03-22-2006 06:21 PM
