Propane real vs. best practices - SailNet Community
 28Likes
post #1 of 53 Old 3 Weeks Ago Thread Starter
I'm just about done replacing the entire dual-tank propane system on my new-to-me old boat, from tanks to stove/oven and heater and everything between. First boat I've owned with propane.
So we all know the best practice is to turn everything off, including the valves at the tank, when not being used. Every book, manual, blog, and forum rat says so. Not a big deal, it's only a couple steps into the cockpit to open and close the valves.
But is that what everyone really does, always?
I have to admit it seems tempting, especially in cool weather after a long day that includes propane use right up to bedtime -- a pre-bed cuppa while warming up next to the propane heater in one's PJs and sleeping cap -- to just close the solenoid and head to bed, then open it again for breakfast in the morning, saving two trips to the tanks. I would off course close the tank valves before leaving the boat unattended for more than a few minutes.
Is that practice pure sin?
Surely more than one drunken sailor has slept off their grog more than once while forgetting to close their tank valves, maybe even forgetting to close the solenoid altogether, and lived to heat up a hangover cure the next morning. No?
Sincerely,
Fastidious and fearful of fiery death
p.s. feel free to pm if you're sure your insurer will read your response and void your policy!
bajaking is offline
post #2 of 53 Old 3 Weeks Ago
Master Mariner
capta's Avatar
Re: Propane real vs. best practices
If you have the solenoid valve properly placed at the tanks (properly installed outside or in a vented locker), I see no reason to turn off the valve on the tank when you are aboard, or just leaving to go out for a few hours, unless you suspect a problem with the system.
If I were leaving the boat for an extended period, then yes, I'd shut off the tank.
If you consider the number of propane equipped boats out there and the number of explosions from the gas, even though many using it do not take any precautions, I'd guess you'd have a better chance of being hit by a meteorite than being killed by a propane explosion.
SanderO and bajaking like this.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #3 of 53 Old 3 Weeks Ago
chef2sail's Avatar
We shut ours off at the tank after using...it’s really no big deal to do that. Yes we also shut off the solenoid.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #4 of 53 Old 3 Weeks Ago
Moderator
MarkofSeaLife's Avatar
Dock
I turn mine off when I go on vacation away from my boat.
Sea Life
Notes on a Circumnavigation:
People can say they want freedom, but offer them the keys to what chains them, a map to where they want to go,
And they'll turn it down for the cell they know
MarkofSeaLife is offline
post #5 of 53 Old 3 Weeks Ago
SanderO's Avatar
Only shut the tank valve when leaving for long periods...leaks (there are none) will drain outboard.
BarryL and bajaking like this.
pay attention... someone's life depends on it
SanderO is online now
post #6 of 53 Old 3 Weeks Ago
Master Mariner
capta's Avatar
"go on vacation"????
Aren't you always on vacation? lol
SanderO, MarkofSeaLife and bshock like this.
capta is online now
post #7 of 53 Old 3 Weeks Ago
Moderator
Dock
Ummmm, yes. When I am on holiday from my vacation
Sea Life
post #8 of 53 Old 3 Weeks Ago
My routine...
When cooking is done..edge of being done..i turn off the tank then solenoid then burner then take pot or pan off burner.
If it is pouring..skip tank..unless sufficiently buzzed that the rain is a short buzz thrill
RegisteredUser is online now
post #9 of 53 Old 3 Weeks Ago
++ for the manual valve is only when I leave the boat for a few days.
The solenoid is for every day use while living aboard or cruising.
One other paranoid idea is when you are done cooking, every once in a while with a burner lit, shut it off with the solenoid instead of the controls on the stove (shut the stove off after the flame extinguishes). It will take you longer to light it next time to get gas in the line, but you'll verify the solenoid works. This is not an every day thing either, but a good test that the system is working.
Y(Paranoia)MV YPMV...and I never want to discourage anyone for being more safe...so whatever floats your boat. Cool you updated everything!
bajaking likes this.
capecodda is online now
post #10 of 53 Old 3 Weeks Ago
fallard's Avatar
Propane leak anxiety? Not on my boat! Our cooking gas is lighter than air—unlike propane, which can settle in the bilge.
We have CNG and once we got a second tank, the inconvenience of limited CNG exchange stations faded. Hopefully, the resurgence of CNG fuel in the non-boating world will turn the situation around to make CNG refills more convenient.
Meanwhile, I don’t turn off the gas while I am cruising. The only downside in not shutting off every evening over the years, is that we had a regulator failure a number of years ago that vented the gas outboard (the good news), but depleted the tank in about 3 days.
fallard is online now
