Downloadable PRINTABLE NOAA Charts - Page 15 - SailNet Community
 26Likes
post #141 of 154 Old 01-05-2016
Skipper Jer's Avatar
Re: Downloadable PRINTABLE NOAA Charts
Thank you original poster for this. Perhaps some one would be so kind as to inform me on how to download and have working on a laptop the graphical chart selector that NOAA has at Interactive Catalog ? The laptop will not be connected to the Internet when I need to look up a chart. I tried saving the interactive catalog while in Firefox, File => Save Page As but what happens when I invoke the saved htm file is a message comes up "Sorry for the inconvenience but the database is temporarily offline, please try back in a couple hours. Thanks."
Not only is a file named " Interactive Catalog.htm" downloaded but a sub directory containing many java script files was included. I think the problem is the location of the java scripts is not where the file "Interactive Catalog.htm" points to. Sorry this is more of a programming question but maybe some one has ran in this problem and solved it. Thanks for any help.
Nor'sea 27
Don't re-accommodate me, Bro
And the trees are all keep equal by hatchet, axe and saw...RUSH
I invented a new word today, plagiarism.
Skipper Jer is online now
post #142 of 154 Old 01-05-2016
Lake Sailor
cb32863's Avatar
This web page won't work "offline". There are links embedded in the source code and you would need to be connected to the net in order for it to work.
Umquam Porro
Seeker 1992 Beneteau First 235
cb32863 is online now
post #143 of 154 Old 01-05-2016
Is there anyway to download all of the files the links point towards so it will work off line?
Nor'sea 27
post #144 of 154 Old 01-05-2016
Lake Sailor
cb32863's Avatar
Highly unlikely as you would need to download the entire parent/child web page hierarchy in addition to all the ancillary files and the charts.
Its not designed to be utilized offline from what I can tell,
Umquam Porro
post #145 of 154 Old 01-05-2016
The most female moderator
Donna_F's Avatar
Dock
If all you want to do is look at the charts and not print, why not use OpenCPN?
miatapaul likes this.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is online now
post #146 of 154 Old 01-05-2016
For some reason or another the resolution and response time of OpenCPN on this laptop was just awful. It would get stuck on a chart view and not respond, resolution reminded me of pong on a black and white TV set. I think what I can do is to download the text file index, NOAA Charts PDF Format then search for the area in question.
Nor'sea 27
post #147 of 154 Old 01-05-2016
Lake Sailor
cb32863's Avatar
You still will not be able to access the PDF's while offline unless you download each one to your computer.
Umquam Porro
post #148 of 154 Old 01-06-2016
Old enough to know better
I think there may be an issue with your install of OpenCPN then, because I have it running on a $65 windows tablet running Windows 10(WinBook) and it is fine. Not rocket fast but quite usable. I have a USB GPS sensor that I use with it. I have heard of folks using it on very old Netbooks. Now if I could read the display in sunlight!
They have a support forum over at Crusers forum and I think one on opencpn.org. I also have it running on my android phone as well.
1976 C&C 33
Project boat, lots of work to be done!
miatapaul is offline
post #149 of 154 Old 01-06-2016
Anarchist in Exile
As others have said, if you just want to view them interactively its best to use a free or low-cost app that will stitch the RNC or ENC files together for seamless (or mostly seamless) viewing.
As for printing, I've never found a local place that will print one full size (and on waterproof paper to boot) for anywhere near the price that you can get them from the NOAA certified suppliers. And what civilian owns a printer that size? Not me.
Navigare necesse est, vivere non est necesse.
jackdaw is offline
post #150 of 154 Old 01-06-2016
I just reloaded NOAA RNC charts and re-installed openCPN. Works much better, looks like it will be usable. Guess there was an issue with the original install. All I need now is a USB GPS device and I'll have a backup chart plotter.
Nor'sea 27
Nautical Architects & Boat-Making Folk: free downloadable books manatee General Discussion (sailing related) 1 01-27-2014 01:23 PM
how to use downloadable charts? copacabana Gear & Maintenance 10 05-06-2010 05:02 PM
Charts, charts, charts.... flyingwelshman General Discussion (sailing related) 6 02-03-2010 08:57 PM
NOAA HELPS OCEAN RACERS AVOID RIGHT WHALES (NOAA News) NewsReader News Feeds 0 05-04-2006 06:15 PM
Downloadable Waypoints NormR General Discussion (sailing related) 0 11-04-2004 05:02 AM
