Child Harness - SailNet Community
Cruising and Sailing with Children All things sailing and kids related, from safety to life aboard.
post #1 of 5 Old 03-04-2015 Thread Starter
Child Harness
We are using climbing harnesses (Edelrid Fraggle) rather than sailing-specific harnesses. The Crewsaver child harness has no crotch strap and the West Marine child harness does not look that strong (it looks like it has no D-ring, tho I never went to see it in person). Also, I just want something to keep them from falling off and will be watching them so I do not expect to be dragging them behind as a sailing harness is designed to do. Plus the harnesses will be fun in their tree fort. For a tether I am using a continuous loop of spectra webbing, cow-hitched to the harness, that provides 45" of tether. They will attach to lifelines with a carabiner that has a safety latch so that it requires two hands to open it.
fecklessdolphin is offline
post #2 of 5 Old 03-04-2015
pdqaltair's Avatar
Re: Child Harness
Do NOT use spectra for a tether, particularly in the tree fort (very dangerous--probably safer to hit the ground). The sudden jolt of the stop can be VERY injurious, and this practice is specifically forbidden by both OSHA and climbing standards groups (UIAA). Use nylon webbing or dynamic rope.
I doubt strength is an issue; the bugger only weighs 30-60 pounds.
The harness should be just fine; a nice high tie-in and fits well. I've used them on children climbing.
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
The Following User Says Thank You to pdqaltair For This Useful Post:
fecklessdolphin (03-04-2015)
post #3 of 5 Old 03-04-2015 Thread Starter
Re: Child Harness
The advice of not using the spectra tether for climbing is very helpful. Used as a tether on the boat, would the connection to a jackline provide the equivalent of stretch?
post #4 of 5 Old 03-04-2015
T37Chef's Avatar
Re: Child Harness
This thread may be helpful
https://www.sailnet.com/forums/cruisi...ss-please.html
Shawn
T37Chef is offline
post #5 of 5 Old 03-04-2015
pdqaltair's Avatar
Re: Child Harness
Yes, when a tether is hooked to a jackline, the jackline provides all of the meaning full impact attenuation. This is well establish both by calculation and in practice.
However, when attached to a cockpit hardpoint, this not the case and several failures have been documented. As a result, the new ISO 12401 standard includes a drop test, which can only be passed by nylon lanyards.
PFD with harness H and E Gear & Maintenance 38 04-04-2014 10:04 PM
stand alone harness or Inflatable with Harness justin_nj General Discussion (sailing related) 5 02-05-2014 07:24 PM
Thoughts on child's safety harness please T37Chef Cruising and Sailing with Children 48 03-30-2010 12:38 PM
rock climbing harness as a sailing harness johnnyandjebus Gear & Maintenance 7 09-22-2009 04:46 PM
PFD with harness sandydil Gear & Maintenance 1 05-04-2005 08:18 AM
