Haulibng Out, Preparing For The Move - SailNet Community
 2Likes
  • 1 Post By overthehorizon
  • 1 Post By Cassidy
post #1 of 2 Old 05-24-2019 Thread Starter
Hauling out, often the head stay has to be removed to fit on the travel lift. How to do it without taking down the sail and messing with the roller furling.
MastUndSchotbruch likes this.
overthehorizon is offline
post #2 of 2 Old 05-25-2019
Cassidy's Avatar
Re: Haulibng Out, Preparing For The Move
Just ease the back stay completely (don’t undo), use a halyard to pull the mast forward and wrap the sheets and furling line around the furler. Then remove the clevis pin. Leave the halyard taut to support the mast. Wrap a towel or similar around the furling drum, lift the drum over the rail and secure somewhere alongside the boat.
No issues with this, our local yard requires this operation on most boats over 40ft.
When you loosen the back stay, leave the lock nuts where they are - that way you can re-tension the rig without guessing. If you don’t have lock nuts, Mark the position with insulation tape. This is assuming the rig tension was
OK to begin with. :-)
Another prep job a lot of folks don’t think about is marking your lift points (for the slings). If you don’t know where they are, do some research before presenting the boat to the travel lift. They’re going to ask.
overthehorizon likes this.
Cassidy is offline
Is it normal for the drive shaft to move in an out by half an inch?? justonemoreproject Diesel 9 05-23-2012 03:45 PM
to move or not to move, that is the question. QuickMick General Discussion (sailing related) 5 10-12-2010 06:58 PM
Where to move to now, so we can eventually move aboard? Chrisbloom7 Living Aboard 21 01-08-2010 11:09 AM
Preparing for a Spinnaker Run lport Racing 1 07-07-2003 03:31 AM
Preparing to go... hayesemily Cruising & Liveaboard Forum 11 02-15-2003 07:22 PM
HTML code is Off
