CS throttle head very sticky - Page 2 - SailNet Community
 1Likes
post #11 of 15 Old 09-23-2015 Thread Starter
Patrick.a7's Avatar
Re: CS throttle head very sticky
Originally Posted by Capt Len View Post
Lots of different adjusters with cotter pins and locking nuts. Those items are so important when reinstalling.
Actually, it's not the cotter pin that I'm talking about. The actual handle, it unscrews, when it does it feels as if that releases tension allowing the whole mechanism to rotate free...er.
Patrick.a7 is offline
post #12 of 15 Old 11-21-2015 Thread Starter
Patrick.a7's Avatar
So... My boat is now on the hard and have had to replace the control head cable. I've the Teleflex cables that were recommended by the CS specialty shop and the problem still seems to be there. Any other ideas on what the problem could be?
post #13 of 15 Old 11-22-2015
How easy was it to run the new cable?
XSrcing is offline
post #14 of 15 Old 02-24-2016 Thread Starter
Patrick.a7's Avatar
The cable went in super easy. The hard part was the contortions I had to perform to use the lazarette. Make sure that the connections match the cable you remove and it will be easy.
post #15 of 15 Old 02-24-2016
Brand/model of the control head? Morse? single/double lever?
Faster is offline
sticky through hulls outbound Gear & Maintenance 0 07-11-2013 06:20 PM
Sticky mainsail tspooner Gear & Maintenance 6 07-05-2012 05:56 PM
Yanmar sticky throttle (3GM30) ddaggett Gear & Maintenance 0 02-01-2011 01:25 AM
sticky traveller Bene505 Gear & Maintenance 7 07-16-2009 02:14 AM
Sticky Mainsail sun37 Gear & Maintenance 22 06-13-2008 08:45 AM
HTML code is Off
