Water System Op - Page 2 - SailNet Community
post #11 of 12 Old 09-15-2015
The handle for the faucet on the CS27 lifts up and acts as a hand pump if the electric pump is not turned into. The faucet it self has an electric switch attached to it, a push button switch that opens when you lift or open the faucet. When the switch is on the electric pump will start. However, the switch can stick and if it does it will not turn the pump on. The switch works the opposite of most push button switches of this type so it may be difficult to find a replacement if it goes. You can take apart the faucet by removing some pins in the handle to get at the switch. Replacement faucets of the same designs are still available online.
Craig Lisk
Former CS27 owner 1158
CraigLisk is offline
post #12 of 12 Old 09-15-2015
Re: Water System Op
Originally Posted by Patrick.a7 View Post
Thank you. I now have water in my sinks. Although, it still has antifreeze in it.
Run the water until the pink runs out. Put another couple gallons of water in your tank and run out again. Do this several times before filling the tank completely.
chuck53 is offline
Water system priming. JeffsTsunami SailNet FAQ 4 06-26-2012 12:20 AM
Water filtration system cla6665 General Discussion (sailing related) 2 09-07-2010 04:17 PM
Fresh water system maureena5 Gear & Maintenance 6 03-07-2007 07:34 PM
pressurized water system jswwrites Gear & Maintenance 2 10-10-2006 11:38 PM
Water system bderosa Gear & Maintenance 4 05-31-2002 04:25 AM
HTML code is Off
