up grade - SailNet Community
post #1 of 5 Old 11-03-2018 Thread Starter
up grade
looking to upgrade from catalina 27 to cs36T 1985 price is 43000 boat is in good shape with inspection is there anything I should be looking for before buying, Looking to travel to Florida and Bahamas from Great Lakes,
whitby is offline
post #2 of 5 Old 11-03-2018
ASA and PSIA Instructor
Re: up grade
Aside from the hull survey and rigging inspection be sure the engine mechanic includes a compression test.
A great boat.
Sent from my SM-G965U using Tapatalk
sailingfool is offline
post #3 of 5 Old 11-04-2018 Thread Starter
Re: up grade
thanks sailing fool I will keep this in mind the engine is a westerbooke
whitby is offline
post #4 of 5 Old 11-04-2018
Dirt Free
boatpoker's Avatar
Re: up grade
I'm a fan, one of the best built production boats ever, but ..... most had solid core copper wiring, the AC ground and DC negative were not bonded. The Propane locker drains were t['d into the cockpit drains, No GFCI's .
Take a look at Marine Survey 101 it will help show you how to inspect the boat.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #5 of 5 Old 11-06-2018
Calmwater's Avatar
Re: up grade
A great fast boat! Iv'e raced CS 30 and won the class almost in every race in New England.
Things to look at, in addition to the engine:
- Standing rigging, blocks
- Railing hardware and connections to the deck have issues - look for interior leaks at these areas
- Plumbing and pumps
As with any boat - a good overall maintained boat, where you can meet and talk with the owner, not just the broker, is easier to survey and reveal any issue. A poorly maintained boat will surprise you with issues forever....
Good luck!
Calmwater is offline
Marine Grade Plywood and Lumber kram General Discussion (sailing related) 7 09-22-2012 03:20 PM
Sail Auckland now ISAF Grade 1 (Scoop.co.nz) NewsReader News Feeds 0 06-22-2006 10:15 PM
Spain. The Trofeo SAR Princesa Sofia on target for ISAF Grade 1 @ BYM Sailing News NewsReader News Feeds 0 04-15-2006 06:15 PM
Marine Grade Plywood? Vastbinder General Discussion (sailing related) 42 07-13-2005 08:37 AM
Products that are NOT marinized or marine grade that work tsenator Gear & Maintenance 23 03-03-2003 08:35 PM
HTML code is Off
