Windlass - SailNet Community
post #1 of 6 Old 12-24-2018 Thread Starter
Windlass
Any recommendations on a windlass for a CS33 ,the anchor locker is not that big. Should modifications be done to enlarge or change it first?
Wanna Bee is offline
post #2 of 6 Old 12-24-2018
Re: Windlass
Youre probably looking at 5/16 G4 chain with 5/8 rope.
A site like Defender will give you the specs on what they carry
RegisteredUser is online now
The Following User Says Thank You to RegisteredUser For This Useful Post:
Wanna Bee (12-25-2018)
post #3 of 6 Old 12-26-2018
krisscross's Avatar
Re: Windlass
You don’t have to keep all the chain on the bow. You can have a detachable section stored somewhere else for time when you need longer chain. Modifying the chain locker is a major PITA
Plato
krisscross is online now
post #4 of 6 Old 12-26-2018 Thread Starter
Re: Windlass
Thanks for the info. and suggestions. I'm upgrading and adding some stuff on my 1983 CS33. I'll head up to the Toronto Boat Show in Jan. and see what is available - and on sale! Thanks SV. Angus
post #5 of 6 Old 12-26-2018
SanderO's Avatar
Re: Windlass
I had excellent service from a Maxwell VWC 1000 and before that VWC 1500.
The windlass should not have to pull a boat against the wind. If you have all chain... and you should... the windlass will take out the slack... catenary becomes "straight". This doesn't take much force... and give the boat some way toward the hook. Take out more slack as a new catenary forms and boat keeps moving forward.
If the chain is tight and no catenary the windlass will work hard to move the boat forward. I found I could use a smaller motor...same foot print
pay attention... someone's life depends on it
SanderO is online now
post #6 of 6 Old 12-26-2018
Master Mariner
capta's Avatar
Re: Windlass
I think it really depends on where and how you intend to use the boat.
For weekending or the occasional week-long cruise, you probably are not going to be headed out when there is a possibility of severe weather, so you can scale your ground tackle back for that use. If you are going cruising, where you can reasonably expect some really bad weather early one morning (3 AM) that could put your boat and life in jeopardy, then you should have ample ground tackle for any eventuality.
I see no reason at all to spend the extra money on expensive high test G-4 chain. BBB is designed as marine anchor chain; G-4 is not! The safety of your ground tackle does not come from the strength of your chain, but rather from its weight (catenary action) and your snub line. I doubt that you will ever sail with any chain that is strong enough alone to hold your boat in big seas if the chain is tight from the anchor to the bow of the boat. That is why we use snub lines and the heaviest chain we can reasonably handle. At the same time, there is little point in a ridiculously heavy anchor. Your ground tackle is a complete system and should be matched to the boat and her use.
Again, depending on where and how you use your boat determines the length of chain to carry aboard. Most cruisers carry at least 200 feet in one length of chain. The idea of having an extra shot or two and connecting it to your main length is pretty unreasonable if one is using a windlass. A shackle will not go through the gypsy on the windlass and a soft link is not something you can just whip out and connect a couple of lengths of chain together in an emergency.
Much better is to have several complete sets of anchor tackle for emergencies if going on an extended cruise to unfamiliar waters. For instance, our #1 is an 88# Rocna on 200' of ˝" chain. Our #2 is a Fortress 55 with 50' of 3/8" chain and 350' of 1" braided nylon. I'll not bother you with the details of #'s 3, 4 & 5, but suffice to say that I expect that should we need to anchor in a hurricane, we will be OK if no other boat causes us problems.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
windlass - mirage 35 drano Gear & Maintenance 2 04-21-2017 02:58 PM
Beneteau 321 Electric Windlass sailmanray Gear & Maintenance 30 03-15-2007 10:47 AM
hunter 40.5 anchor windlass DONLESLIE Gear & Maintenance 2 05-30-2006 09:33 PM
Anchor Windlass DICKWATERS Gear & Maintenance 1 07-27-2001 05:59 PM
Electric windlass - options Guylain Gear & Maintenance 8 05-01-2001 03:48 PM
HTML code is Off
