CS30 Plumbing - SailNet Community
post #1 of 4 Old 07-04-2019 Thread Starter
CS30 Plumbing
I'm looking for some fittings to replace faucets in the head and galley. Does anybody know what size the plastic piping (assuming it's pex) is on CS30? Thank you in advance
Tchaidog is offline
post #2 of 4 Old 07-04-2019
Re: CS30 Plumbing
I dont think itís necessarily a standard. From what Iíve seen so far, there are a variety of plumbing solutions used by builders, sometimes even the same builder, depending on era. Probably best to take some pics and try and finding identifying print on the lines. Some of the stuff used in the 80ís and 90ís is no longer made. Mine looked like Pex, but it isnít, its a propriety line called Parker Parflex Polyproprelene used with nylon compression fittings.
Zemurray is online now
post #3 of 4 Old 07-04-2019
Dirt Free
boatpoker's Avatar
Re: CS30 Plumbing
PEX was not OE in CS Yachts.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #4 of 4 Old 07-08-2019
al brazzi
Re: CS30 Plumbing
I am in a CS30 now, no Pex, all clear reinforced vinyl hose on H&C water plumbing. In 5 years I've done just about everything that's needed and a lot that's not, if you know what I mean. Anything I can do to help just ask.
albrazzi is online now
HTML code is Off
