Universal to Kubota Parts list? - Page 7 - SailNet Community
 6Likes
post #61 of 64 Old 05-13-2015
Re: Universal to Kubota Parts list?
I've no idea where you got $500 from, for the marinised exhaust manifold. As far as I know, they are not available new for any price. In fact, if you know where to get one, let me know, because I'll buy one right now.
Cost of boat : $45,000
Cost of re-power : $15,000
and you're panicking about $500 for a manifold, which might extend the engine life by 10 years?
MarkSF is offline
post #62 of 64 Old 05-13-2015
Originally Posted by brownoarsman View Post
Hey Rafael - I was looking at the same thing and received the same dire warnings about running a dry manifold. Is yours still working alright - did you insulate it at all with wrap? Are you running at cruising rpm (2400 rpm) for sustained periods (multiple hours in a row vs. just exiting harbor?) I assume you've just led a hose from the top of your block to your mixing elbow to inject the water into the exhaust. Thanks!
The issue with a dry manifold is not so much the radiated heat, it's the exhaust temperature entering the rest of the exhaust, which is made with RUBBER hosing. In fact, wrapping the exhaust manifold will make the exhaust gases HOTTER.
MarkSF is offline
post #63 of 64 Old 05-13-2015
Hi Mark,
My boat is certainly not worth what you quoted, and while I won't be sure until I get the head off (it's stuck to the block pretty securely and is soaking in Sea Foam now), I seriously doubt that my engine has 15 years left in it!
Here is the manifold listed at Torreson if it could help you (for $550) Universal 300418 Sailboat Supplies, Engine Parts and Boat Parts
At least on my engine, the rubber exhaust hosing doesn't begin until after the water is injected (the riser is made of iron) and the water would mix with the exhaust down the last fall in the riser, passing through four inches of rubber exhaust hosing, and combining in the water muffler. I'm honestly interested in Rafael's experience running a dry manifold as the alternator and starter are very close to the exhaust manifold and I'm curious as to whether they've suffered damage! My manifold is probably okay right now (getting it pressure tested at the machine shop when I take the head in) but curious as to how it worked out for Rafael.
Also, Rafael, did you have any issues getting your head off? Mine seems stuck on with superglue (most likely due to saltwater corrosion around one of the studs and a bolt). I've tapped it with a rubber mallet, hauled on it with a block and tackle, poured sea foam down the stud/bolt holes, and turned the engine over with the glow plugs and injectors in trying to get the compression to blow it off - but no luck. Please share any tips you used!
brownoarsman is offline
post #64 of 64 Old 10-19-2015
I would like a copy of 5411 parts book. thank you jim [email protected] I have a Newport 27 in hyder Alaska thanks.....
captjimhyder is offline
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
My Universal 5416 is which kubota engine?? deniseO30 Diesel 19 08-10-2014 01:57 PM
Universal Atomic Parts Dave_E Diesel 5 09-04-2013 09:01 PM
Universal M25XP / Kubota D950 question kaptaindave Gear & Maintenance 8 12-02-2009 12:39 PM
Kubota parts number RussT1950 Diesel 1 11-29-2009 07:47 PM
universal/kubota Alternators deniseO30 Diesel 4 11-05-2009 04:29 PM
