Shaft out of alignment - touching hull - SailNet Community
 2Likes
post #1 of 11 Old 12-05-2014 Thread Starter
The shaft of my 3gmd is off on the side towards port.
Should I be able to loosen engine mount and move the shaft starboard a few mm
Can I do this on the hard ?
wrapper is offline
post #2 of 11 Old 12-05-2014
Master Mariner
capta's Avatar
Re: Shaft out of alignment - touching hull
You should probably check your shaft and strut as well. Pull the cutlas bearing and check the wear. This appears to be way too much out for just the engine, but I'm not there so I can't say this for sure.
Is it possible you hit anything with the strut or prop recently?
Faster likes this.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #3 of 11 Old 12-05-2014
Learning the HARD way...
eherlihy's Avatar
That's putting it mildly...
You should, but as the previous poster states, you should check your strut (and cutlass bearing) and your shaft seal (either dripless or stuffing box) too. You will be moving the entire drive line to starboard, and will need to realign the engine.
Yes!
USCG Licensed OUPV Captain, ASA 101/103/104/105/106/114/118 Instructor - Also certified in Marine Electrical Systems
eherlihy is online now
post #4 of 11 Old 12-05-2014
eherlihy's Avatar
...But on the positive side of the ledger, it looks like you don't have to worry about barnacles.
post #5 of 11 Old 12-05-2014
Master Mariner
capta's Avatar
On the hard you can align the engine but it will not necessarily be perfect. If the strut and shaft are good, then do the alignment on land and fine tune it after a few days sitting in the water.
The flanges for the trany/shaft connection are where you measure the alignment, not outside the boat where you see the problem. Undo the bolts and you will see if the two surfaces of the flanges line up. You will be working in hundredths of an inch here, not visually. You will need to loosen all 4 motor mounts and have a set of feeler gauges to use. The flanges must line up as nearly perfect as you can get them, both as parallel flat surfaces and the outer circumferences.
If the flanges line up or you cannot get them to line up at all, and you still have the offset where the shaft exits the hull, you have a bent or improperly installed strut or bent shaft. Spinning the shaft by hand against a fixed point, (a 2 X 4 clamped to the rudder, a stand, etc.) will tell you of a major bend.
Checking the alignment of the strut may be something only a yard can do, unless you have the specific tools.
capta is online now
post #6 of 11 Old 12-05-2014
Don't call me a "senior"!
Puddin'_Tain's Avatar
Given that there appears to be that much misalignment I would be willing to bet that: your strut is loose, you cutlass bearing is shot, your strut is or way out of alignment, or some combination of these. Best thing to do is to uncouple the shaft from the transmission and see where it wants to line up with just the strut/cutlass to guide it. Make sure that the shaft isn't loose in the cutlass bearing and that the strut is firmly attached to the boat. If those are OK, you can start playing with the alignment.
"If a man must be obsessed by something, I suppose a boat is as good as anything, perhaps a bit better than most." --- E.B. White
Puddin'_Tain is offline
post #7 of 11 Old 12-05-2014
Dirt Free
boatpoker's Avatar
Don't pull the trigger too fast. I see this all the time and it does not mean anything is out of line. Many boats leave the factory this way, The "glass" all around the shaft aperture is most often about a 1/2" of gelcoat manually (crudely) applied after the hull came out of the mold. Before taking action check the flange coupler with a feeler gauge, inspect cutless bearing and strut securement.... if they are ok then you have nothing to worry about.
christian.hess likes this.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #8 of 11 Old 12-06-2014
TQA
Bombay Explorer 44
TQA's Avatar
I would take a real hard look at your engine mountings and the engine bearers themselves.
If nothing obvious then watch what happens when someone puts it in gear forward then reverse. Sometimes engines are just sitting loose on broken mounts or bearers.
TQA is offline
post #9 of 11 Old 12-07-2014
JimsCAL's Avatar
A Cat 30 in our club had been running with a similar issue for years. The fiberglass was worn almost completely through before it was caught. It required removal of the shaft so the fiberglass work could be done.
JimsCAL is offline
post #10 of 11 Old 12-07-2014 Thread Starter
She always vibrated when turning under power.
The propeller caught the dinghy line probable made it worst.
A couple people looked and said cutlass looked good. Strut looks and feels solid.
Sent from my iPad using Tapatalk
wrapper is offline
Tags
alignment , shaft
shaft alignment jfitzgerald Gear & Maintenance 6 03-04-2014 05:02 AM
Prop shaft alignment H and E Gear & Maintenance 1 12-03-2013 09:41 AM
Shaft Alignment: Alignment causes mount problems lizardheadone Gear & Maintenance 12 11-24-2013 10:29 AM
2GM20F Shaft Alignment... mm2187 Gear & Maintenance 5 04-11-2013 10:29 PM
Proper shaft alignment Joshua Dawn Gear & Maintenance 20 12-13-2009 05:17 PM
