Where to our get our Hurth HBW-360 rebuilt? - SailNet Community
 1Likes
post #1 of 12 Old 12-27-2014 Thread Starter
Glad I found Sailnet
Bene505's Avatar
Sad to say our transmission no longer works in forward gear. Yes, I checked the linkages. I even disconnected the linkage and shifted it into gear right at the transmission. It happened immediately after some aggressive shifting to maneuver to a dock in a high wind.
Does anyone know the best place to get it rebuilt?
We are currently in New York. I called Transatlantic Diesel but they don't do transmissions.
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #2 of 12 Old 12-28-2014
RichH's Avatar
Re: Where to our get our Hurth HBW-360 rebuilt?
I would HIGHLY recommend: East Coast Marine Transmission
Located in South Amboy NJ, just off the Raritan Bay.
This fellow is a true mechanical 'artist' and was the lead transmission mechanic at MackBoring Co. for about 25-30 years before they stopped/ceased rebuild and repair work on Diesels and Transmissions. MackBoring also HIGHLY recommends him. My experience (a stint in the engineering and design and application of large traction drive gear reduction units) is this fellow has incredible 'feel' in his finger tips with (epicyclic) gear lash and clearances - a real 'craftsman', not a parts replacement hack.
His customer base includes most of the independent Yanmar Distributers in the New England and MidAtlantic area.
RichH is offline
post #3 of 12 Old 12-28-2014 Thread Starter
Bene505's Avatar
Thanks Rich,
I emailed them and will call them this week.
Regards,
Brad
Bene505 is offline
post #4 of 12 Old 12-28-2014
FWIW elsewhere recently someone stated the cost of a new replacement was $200 more than a rebuild.. Have you checked that 'angle' out yet? (could be, though, that such a skilled rebuild may be better than new??)
Years ago I was told by a Hurth dealer that these gears were essentially considered 'disposable' We're currently into year 11 or 12 (~1400 hrs) on ours (replaced by the PO).. some 'new' noises but still driving well.
On a previous boat we ran 12 years on same gear while we had it, no idea how old or new it was, but the next owner had to change it out almost immediately. Odds are this item will be on our list soon
Faster is offline
post #5 of 12 Old 12-28-2014
RichH's Avatar
an new??)
Not only with the recent 'crop' of marine transmissions; but, also the same with automotive transmissions and differentials .... no longer use 'hardened' gears, etc. and simply depend on actuarial statistics of failure mode - a dependence on statistical accounting functions rather than any possibility of 'over engineering' to assure long term service life.
Too damn bad if the geared device you own happens to be an 'outlier' of that statistical range.
RichH is offline
post #6 of 12 Old 12-31-2014
CaptNemoO2's Avatar
I had mine rebuilt at LI Marine Engine and Trans in Deer Park. It's most likely the clutch pack that went bad. Mine did the same, but reverse went while docking. If I remember correctly it was around $1500. I pulled and reinstalled the transmission my self. The guy was really nice, but he told me the parts are getting hard to find. He was told that they stopped making the transmission around 1990. It was already obsolete when installed in my 93. Is yours the 360 or 360A? There is a ZF transmisson, I believe the 63, that is almost a direct fit. It is a little shorter than the 360A, same angle. To fit it into my boat, I would of had to shim the engine a little higher, less than .25" and use a drive saver to make up the difference in length. If you have the 360 (straight output flange) you may be good to go.
Edit: Found this link that has the parts to give you an idea of the cost... http://www.merequipment.com/products...60a-parts.aspx
CaptNemoO2 is offline
post #7 of 12 Old 12-31-2014 Thread Starter
Bene505's Avatar
Edit: Found this link that has the parts to give you an idea of the cost... Marine Transmission Parts, Clutch and Seal Kits, Gaskets and Marine Transmission Service Manuals
Thanks for the post. Yes, it is a 360 with a straight output flange.
I'll look into the ZF63.
Regards,
Brad
Bene505 is offline
post #8 of 12 Old 01-01-2015
CaptNemoO2's Avatar
Regards,
Brad
Good luck! When I looked into it, I believe that the transmission was $2400, and was way overkill for the application. In the end I decided to have the transmission rebuilt and saved $1000. I figured the tranny went 20 years and 1600 hours, if I can get another 1600 hours out of it, I'll be ok! Now if I was doing some serious cruising, I would consider getting a new tranny that isn't past it's EOL on the production line. But because I had a down angle tranny, I was in a unique situation where I had to match the angle, flange height and distance. Being that you have a straight output, you can probably find several transmissions that will work. Your shaft would either move aft, or forward assuming you have room, or use a drive saver to make up the difference. There's always the Borg Warner velvet drives. And there were two lesser known transmission companies that had similar products, but I don't remember their names, but did find them through message boards. The hurth had a standard SAE bellhousing mount, I think it was SAE 3. Going with a non hurth may require changing out the damper plate.
BTW, where in NY are you?
post #9 of 12 Old 01-02-2015
aeventyr60's Avatar
Keep the faith on that Hurth tranny. I got 4300 hours and 19 years out of this one before having it rebuilt last year in Thailand. The seals went, lost fluid and then the noise. Part were readily available here, and the one part that wasn't available they were able to machine a new one.
Parts were about $350. Labor to pull and re install the tranny plus redo the rear main seal on the Perkins 4108 was $200. All done while on the hook.
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
post #10 of 12 Old 01-02-2015
Old enough to know better
Gotta love that labor rate! I think $200 around here gets about 15 minutes of work! might almost be worth sailing to Thailand
Faster likes this.
miatapaul is offline
Hurth HBW-5 Transmission KVK Diesel 16 01-28-2016 09:19 PM
Hurth HBW-5 won't shift mwielicki Gear & Maintenance 1 04-17-2010 12:55 AM
Hurth HBW 50 Core Value? Pub911 Gear & Maintenance 3 02-08-2009 10:16 PM
Hurth HBW 50 vs. ZF-5, ZF-6 or ZF-10 Pub911 Gear & Maintenance 2 02-03-2009 08:44 AM
Flushing Hurth HBW transmission lindafirpo General Discussion (sailing related) 1 06-16-2008 11:56 PM
