raw water puzzle - SailNet Community
post #1 of 13 Old 05-06-2015 Thread Starter
davidpm's Avatar
raw water puzzle
Oday 35 with Universal M-25XP
It looks like the raw water has a hose that goes to the mixing elbow as expected. What is surprising that the the hose that goes to the mixing elbow has to t fitting an another hose that runs all the way to the back of the boat and their is another mixing type fitting into the exhaust just before it exits the back of the boat.
What is the purpose of the second mixing elbow.
The small hose going into the big hose is what I'm talking about.
davidpm is offline
post #2 of 13 Old 05-06-2015
islander bahama 24
newhaul's Avatar
Re: raw water puzzle
Sounds and looks like a syphon breaker
Illegitimus Non Tatum Carborundum.
newhaul is offline
post #3 of 13 Old 05-06-2015
Water lying in the small hose may prevent air from entering the system. This causes the engine to fill with raw water. This is annoying.
Capt Len is online now
post #4 of 13 Old 05-06-2015
It looks like your exhaust is going overboard through a plastic thru-hull. That can't be good.
I'd be afraid the plastic would crack and let CO into the boat.
Hoses are all double clamped, that's good.
hopcar is offline
post #5 of 13 Old 05-06-2015
I may want one of those myself. LOL. Where does the little hose go?
Zen is a matter of recognizing reality.
desert rat is offline
post #6 of 13 Old 05-06-2015
Schooner Captain
UnionPacific's Avatar
Plastic thruhulls? Woah, you have bigger issues here.
Also no seacocks...
your a sinking, looking for the right day to happen.
UnionPacific is offline
post #7 of 13 Old 05-06-2015
islander bahama 24
newhaul's Avatar
Seacocks not needed all these thru hulls are above the waterline I assume
newhaul is offline
post #8 of 13 Old 05-06-2015
RichH's Avatar
This 'octopus' drains well 'above' the water line, does it?
If not, those nylon through-hulls are a BAD idea, as nylon 'hydrolyses' (weakens) in constant contact with water and exposure to UV.
The small clear (well degraded) plastic line from the siphon break (?), is probably a 'pisser' - it discharges into the small plastic hose and then overboard; in this case most probably the vent valve in the siphon break has been removed - stupid!.
If this 'octopus' is very close to the water line, its a good way to sink a boat. If so rip it out, install a 'sea chest' (common discharge manifold with proper single bronze sea-cocked through hull).
This boat hasn't passed a rigorous insurance survey in a very long time; since the mid 1970s ... correct?
RichH is offline
post #9 of 13 Old 05-06-2015
Schooner Captain
I would make the same assumption, unless he is healed.
Plastic is easy to snap, and a very poor choice for anything larger then a bass boat.
post #10 of 13 Old 05-06-2015
islander bahama 24
newhaul's Avatar
Look closer the exhaust is bronze just needs a lil cleaning the rest of them appear to be standard plastic thru hulls commonly used above the waterline
newhaul is offline
converting raw water head to fresh water rmeador Gear & Maintenance 17 06-02-2011 03:12 PM
Raw water cooled issues and hot water davidpm Diesel 5 11-12-2009 06:11 PM
A4 Exhaust Raw Water Elixir7 Atomic 4 9 11-11-2009 04:05 PM
Raw Water Cooling - No Water Coming Out montenido Gear & Maintenance 20 01-21-2009 05:16 PM
Connecting raw water cooling to water heater Northeaster Gear & Maintenance 18 04-28-2007 07:11 PM
