Grounding M4-30? - SailNet Community
post #1 of 8 Old 07-02-2015 Thread Starter
Question Grounding M4-30?
If you have a Universal M4-30 diesel: to which engine block bolt is your negative battery cable connected?
Mine is connected to the lower starter mounting bolt, which is nearly inaccessible in my install. The service manual does not suggest a particular bolt to use. I'm curious as to what others have done.
1975 Tartan 30 Competition Rig
eko_eko is offline
post #2 of 8 Old 07-02-2015
celenoglu's Avatar
Re: Grounding M4-30?
The engine body is general negative terminal. The place of the connection will not make any difference electrically.
celenoglu is offline
post #3 of 8 Old 07-02-2015 Thread Starter
Well, yes, technically. Some bolts are a better idea to use than others. I've heard that one should not use the alternator mounting bolt (possibly because it slides?).
I'm looking for places where other users have been able to successfully put a ring terminal without interfering with some other engine function, experiencing too much vibration, etc.
eko_eko is offline
post #4 of 8 Old 07-06-2015
Stu Jackson's Avatar
Originally Posted by eko_eko View Post
..... without interfering with some other engine function, experiencing too much vibration, etc.
Everything on the engine vibrates equally.
Just find an easily accessed big bolt, and make sure it's cleaned before you attached your ring terminal.
No need to make this any harder than it need be.
Other folks may have the same engine, but access could well be completely different. The only way you'd get an answer to you specific question is to find someone with the same exact boat AND engine.
Good luck.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #5 of 8 Old 07-06-2015 Thread Starter
I didn't want to use something like the alternator or starter mounting bolt. I found that there are several M10x1.25 threaded holes along the side of the motor, presumably for an alternate mounting scheme. I've picked up a new bolt and will be running my grounding lines there.
eko_eko is offline
post #6 of 8 Old 07-07-2015
Less Senior Senior Member
Similar to mine. What boat?
seaner97 is offline
post #7 of 8 Old 07-08-2015 Thread Starter
Tartan 30. I wanted to use a bolt that I'd have no reason to adjust other than to replace these cables, and also one that was less likely to shake loose and easier to check on.
eko_eko is offline
post #8 of 8 Old 07-08-2015
Sounds like you've picked the right way to go.
seaner97 is offline
Tags
universal electric
DC/AC grounding Seascape Gear & Maintenance 13 04-03-2013 03:00 PM
Grounding fmueller General Discussion (sailing related) 3 03-19-2012 10:40 AM
Grounding the Through Hulls? rbrasi Gear & Maintenance 0 04-18-2011 03:33 PM
Grounding Coreyboy18 Electrical Systems 11 05-02-2009 12:21 PM
Mast Grounding jmedina General Discussion (sailing related) 3 08-16-2001 02:57 PM
