Shaft Coupling Stuck to Transmission Flange - Page 3 - SailNet Community
 11Likes
post #21 of 31 Old 09-09-2015
Tartan 27' owner
CalebD's Avatar
Re: Shaft Coupling Stuck to Transmission Flange
That is just nutz!
Wishing you a swift recovery.
Everybody has one:
CalebD is offline
post #22 of 31 Old 09-09-2015
That's the problem with production knobs. They just don't build 'em like they used to. 'Better give the jewels a rest for a while . How about a thin SS strap ,(about 4 inches wide)U shaped with eye ring on one leg. Open door, slip over edge, close door.most doors have enough clearance. Be sure the door opens away or the lacerations could be severe when someone comes thru.
Capt Len is online now
post #23 of 31 Old 09-09-2015
ericirvine's Avatar
I know I'm coming in a bit late here but I've attached a couple of photos of the coupler you have that might help visualize what you are dealing with. Mine is attached to the Hurth transmission on my 5416 engine.
As you can see on the transmission side there is a kind of cross arrangement that the bolts pass through. on the blue coupler you can see a circular lip, that engages the inside of the "pads" on the end of the cross arms. That is a pretty tight fit if I remember right, even without it being rusted solid. I think I just used a thin metal wedge tapped in between the flange and each of the cross piece arms to separate them.
Don't use heat on this coupler unless you are prepared to replace it. The big bolts on the outside pass through rubber bushes that will be ruined by heating.
HTH
Eric
Faster likes this.
ericirvine is offline
The Following User Says Thank You to ericirvine For This Useful Post:
brownoarsman (09-18-2015)
post #24 of 31 Old 09-10-2015
Good info Eric.. I suspect you've nailed the issue. Once the oarsman isn't walking bowlegged that should help him out.. the power of the wedge may well be the trick.
Oarsman.. I'm happy to say I don't 'feel your pain'... but you have my sympathies and thanks for sharing..
Faster is offline
post #25 of 31 Old 09-10-2015
overbored's Avatar
Thats all he needs now is the power of the wedgie
"GOLD RUSH" PRINDLE 16
overbored is offline
post #26 of 31 Old 09-10-2015
Old salt, new2me boat
The answer seems so obvious... attach the PT exercise band to the coupling! But be prepared to jump!
RustyPelican is offline
post #27 of 31 Old 09-18-2015 Thread Starter
Thanks for the tips and humor! They certainly brought a smile. I'm well on the road to recovery, and should be able to get back on the boat after another week or two.
Eric - those pics are super helpful, and, though your arrangement is much cleaner, looks like mine! Do the cross arms grip that coupler lip at all? Or do they just sort of rest on it. Back when I was in the laz working on it, I tried putting my thin pry (actually, a thin steel putty knife) in between the coupler and the flange arm and giving the pry some light taps, but couldn't get the wedge into the seam - I assume because of the corrosion. Did you have a similar experience? Just wondering what you meant by the lip engaging the cross arms of the flange. Thanks!
brownoarsman is offline
post #28 of 31 Old 09-18-2015
Just guessing here but thinking that the cross arms are centered in the unit by the lip. Methinks a bit of engish on the handle of a big screwdriver could set things moving.
post #29 of 31 Old 09-19-2015
The arms don't look very strong and probably bent pretty easy so be very careful. A disc shaped coupler would be a lot stronger, but all the smaller Hurths and maybe the big ones too use this type. Mines never gotten stuck so bad the a very light tap didn't break it loose.
capt jgwinks is offline
post #30 of 31 Old 09-19-2015
ericirvine's Avatar
Oarsman,
Great to hear you are on the mend, and thanks for sharing your adventure with the doorknob. It took me while to get off the floor when I read it, before trying to give a serious answer to your engine problem. Glad you could see the humor in spite of the pain ?
To your questions, the inside lip on each of the four cross arms has been machined to match the outside of the circular lip on the coupler. It's a tight fit. On the photo of the coupler you can see the shiny spots where the cross arms meet the coupler face and lip.
I have a very thin wedge that is about 5 inches long, 1 1/2 inches wide and tapers from about 3/8 inch down to almost zero. It's made of hardened steel, my old journeyman gave me it when I was an apprentice about 30 years ago. He called it a "fox wedge", and it has saved my bacon on a few occasions over the years. So it's much thinner than a screwdriver tip, and the taper is very gradual. It would be easy to make one with a bit of steel bar and a bench grinder. I tapped it in to each of the 4 meeting points in turn, a little at a time. I soaked them in PB Blaster beforehand.
Get well soon
Eric
Installing prop shaft flange/transmission coupling jimgo General Discussion (sailing related) 11 04-21-2014 08:39 PM
Transmission output flange fell off Yanmar 2QM15 - Theories re: why? JeffBurright Gear & Maintenance 33 02-13-2013 07:06 PM
Transmission coupling bobdamiano Diesel 9 05-11-2010 07:27 PM
Male pilot coupling optional for output flange? Flugeler Gear & Maintenance 1 07-31-2009 09:16 PM
shaft coupling clifsail Announcements and Suggestions Box 1 08-15-2006 02:06 PM
