Shaft Coupling Stuck to Transmission Flange - SailNet Community
 11Likes
post #1 of 31 Old 09-03-2015 Thread Starter
I'm in the middle of removing my universal 5411 engine mated to a hurth transmission, and have a pressing (ha-pun!) question before I lose the community dock to the Labor Day weekend. Everything is off the engine - except that the prop shaft and its coupling are still connected to the transmission flange, even though I've removed the four bolts connecting the coupling to the transmission flange. The packing nut is all the way loose and leaking water when I wriggle the engine (the shaft is moving because it's still somehow connected to the transmission), but I can't push the prop shaft coupling and shaft back from the transmission, or move the engine forward with the two still locked together. Knowing that transmissions are surprisingly fragile and unsurprisingly expensive, I don't want to force anything. The eight hours of internet searching all make this seem easy (e.g. remove four bolts, loosen the packing nut, and slide it on back!), with the issues arrising when people need to remove the coupling from the shaft - but this is not my problem. I want to leave the coupling attached to the shaft, but just remove the coupling from the transmission so I can lift the engine to take the head off.
Here is a picture of the coupling and transmission connection, I've removed the four bolts shown in the picture already:
Please let me know if you have any suggestions, and thanks!
brownoarsman is offline
post #2 of 31 Old 09-03-2015
Re: Shaft Coupling Stuck to Transmission Flange
Looks like an old 'drive saver' coupling.. could it be there are bolts on the transmission side too? Also many couplings have 'blind' threaded holes that can be used with bolts to separate the two halves.. maybe have a look for that too.
Also... maybe you're trying to separate the wrong parts??
RichH likes this.
Faster is offline
post #3 of 31 Old 09-03-2015 Thread Starter
Here is a link to the transmission schematic as well: http://www.catalina30.com/TechLib/En...5411_PARTS.pdf The transmission flange is shown in section 26. Thanks!
post #4 of 31 Old 09-03-2015
Yes, but the 'fat' part of your coupling, indeed the coupling itself regardless of type, is not part of the transmission. The gearbox drawings end at the output flange, to which the coupling connects.
I agree your shaft should disengage based on removing the 4 bolts, but I don't think the entire coupling body will. Though it looks a bit different from the one in my posted picture, it still looks like a 2-part drive saver - meant to minimize vibration due to slight misalignment.
I can see nuts on the tranny side of the output flange.. if you can get those off the entire thing could separate from the tranny flange.. allowing you remove the engine/gear.
Faster is offline
post #5 of 31 Old 09-03-2015 Thread Starter
Thanks for the thoughts Faster! It's certainly a weird looking thing and doesn't resemble any of the couplings I've seen on other threads and blogs. Sadly, both faces of the coupling are smooth, so I don't think blind holes exist, and I can't see any other ways of fixing the shaft in place, except for maybe those big screws mounted in rubber that are just barely visible in the above picture on the sides of the coupling. The four bolts shown match up to the transmission diagram in the parts manual (sorry I didn't upload it before - very slow computer).
I thought maybe the shaft was threaded and somehow locked into the transmission, but I can't get the shaft and the transmission to turn independently either.
post #6 of 31 Old 09-03-2015
JimsCAL's Avatar
I had a 5411 on my previous boat and my coupling looked nothing like your picture. Mine had the "four arm" coupling at the transmission as shown in the Universal manual. Four bolts would disconnect the shaft coupling from the propeller shaft. Yours looks pretty corroded and I'm sure that's part of the problem.
JimsCAL is online now
post #7 of 31 Old 09-03-2015
overbored's Avatar
that is a federal flex coupling it has set screws that hold the shaft to the inner part and the big nuts hold the inner hub in the outer ring. there should be flange on the trans that bolts to the outer ring.
Marine Transmissions, Velvet Drive, Paragon, marine transmission parts,
Faster and oldfurr like this.
"GOLD RUSH" PRINDLE 16
overbored is online now
The Following User Says Thank You to overbored For This Useful Post:
brownoarsman (09-03-2015)
post #8 of 31 Old 09-03-2015
Well done, OB!
This should help the OP quite a bit.
Faster is offline
post #9 of 31 Old 09-03-2015
overbored's Avatar
Well done, OB!
Thanks, I somehow remembered the name. I removed one from our PC sloop way back when I was kid.
post #10 of 31 Old 09-03-2015
Slightly clearer, cleaner drawings:
http://file.seekpart.com/keywordpdf/...1843016797.pdf
It does look, now, however, that the entire coupling assembly SHOULD disengage from the tranny's output flange if the 4 bolts are out.. so it's gotta be corrosion holding things up or (thinking externally) if a shaft zinc is too near the strut the prop shaft won't slide out either...
Hope all this helps you out a bit, brownoarsman!
Faster is offline
The Following User Says Thank You to Faster For This Useful Post:
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Installing prop shaft flange/transmission coupling jimgo General Discussion (sailing related) 11 04-21-2014 08:39 PM
Transmission output flange fell off Yanmar 2QM15 - Theories re: why? JeffBurright Gear & Maintenance 33 02-13-2013 07:06 PM
Transmission coupling bobdamiano Diesel 9 05-11-2010 07:27 PM
Male pilot coupling optional for output flange? Flugeler Gear & Maintenance 1 07-31-2009 09:16 PM
shaft coupling clifsail Announcements and Suggestions Box 1 08-15-2006 02:06 PM
