Primary Bosch Fuel filter & water separator help finding part - SailNet Community
post #1 of 3 Old 04-11-2016 Thread Starter
Lifted the cockpit sole to access fuel filter & water separator, it's a Bosch with the following part no stamped on top. 0450 198 009
I have searched online all morning and can't find a replacement filter anywhere.
1) Does anyone recognise this type, or know if there is an OEM filter that would be compatible ?
2) Does the second water separator bowl also screw off for replacement ? I can't find any documentation about this online. The engine is a Yanmar 1GM10
The engine runs fine, I drained fuel from each in turn and fuel looked clean and uncontaminated and no water. I have only recently purchased boat, engine has done 368 hrs on clock, so wanting to replace filters for new season. I'm in the UK.
Rowman is offline
post #2 of 3 Old 04-11-2016
Re: Primary Bosch Fuel filter & water separator help finding part
Bosch is primarily an Automotive gas and Diesel fuel filter. Not surprised you did not come up with anything on the Part Number, but alot on the Automotive filters. I believe once you take the element out, you may have a number. Take it to Autozone, Pep Boys or any other automotive parts store and they may be able to reference it. If not...Time to change it out to a Racor.
Stephen
1983 Cabo Rico 38
S/V New Wind
"It isn't that life ashore is distasteful to me. But life at sea is better."
-Sir Francis Drake
stpabr is offline
post #3 of 3 Old 04-11-2016
overbored's Avatar
that is a common filter used on diesel cars and trucks in the UK and europe. take it to an good auto parts store and they should be able to match it. that is a good part number because it come up on ebay UK. Bosch Water Separator 0450198009 | eBay
I had a 1GM10 and it is a very good engine. that filter is a bit overkill for that engine and there are two of them. should last 1000 hours on that engine.
"GOLD RUSH" PRINDLE 16
overbored is online now
Tags
diesel fuel filter
Yanmar diesel fuel filter water separator oksailor Diesel 8 06-29-2014 03:53 PM
installing a fuel filter/separator blisscloud9 Diesel 3 05-07-2011 09:01 PM
Primary fuel filter Jotun Gear & Maintenance 30 12-19-2010 03:01 PM
Clogged Primary fuel filter. L124C Diesel 12 12-19-2010 01:42 PM
Fuel filter/water separator Waltthesalt Diesel 8 01-08-2010 10:00 PM
