Yanmar 3YM20 Regular Service Cost? - Page 2 - SailNet Community
 4Likes
post #11 of 13 Old 04-12-2016
weinie's Avatar
Re: Yanmar 3YM20 Regular Service Cost?
Originally Posted by Zoya View Post
Hey Weinie, that's Thierry from Jeanneau 349... I guess I'll have to start the oil change thread in the forum "Maintenance" topic
Hey bro!
It's a piece of cake to change the oil, oil filter, and both fuel filters. I usually do it in the fall as part of the winterization process. They say its better to leave fresh oil in the engine while it sits on the hard.
Get a good oil pump. Mainesail suggested the Moeller one and it really works well. Be sure to change the o-rings on the fuel filters too.
Here's the stufff you'll need
Yanmar 3YM20
(The primary filter on our boat, not indicated is YAN41650-502320 )
Zoya likes this.
weinie is offline
post #12 of 13 Old 04-12-2016
Daniel - Norsea 27
Rhapsody-NS27's Avatar
Thanks all for responding and passing along useful advice. I am actually pretty handy and do regular maintenance on my motorcycle myself but marine engines are new to me and I was actually a bit intimidated by the oil extraction process... so thanks to Rhaphsody-NS27 for passing on the oil pump tip. The Yanmar 3YM20 on my boat is so easy to access and so is the impeller that I also doubt it could take more than 2 hrs to get this done.
Take care,
You have some nice access to your engine. Nice the impeller faces forward.
Like suggested, warming the engine will help.
Enjoy
Zoya likes this.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is online now
post #13 of 13 Old 04-12-2016
I guess I can only add that if the same person gave the range of time it was an estimate, not a quote. Not seeing the installation first, it is difficult to give a fair estimate. Impellers can be a real pita if stuck usually from not being changed or serviced regularly. I have had to remove the pump to a bench on many occasions. With your experience you should have no problem doing these tasks yourself.
captjcook is offline
Yanmar 3YM20 belt change NewportNewbie General Discussion (sailing related) 1 09-28-2013 02:51 AM
Expected life of Yanmar 3YM20 donjuanluis Diesel 1 09-25-2013 08:36 PM
Yanmar 2YM15 Or 3YM20 for repower jbrockpiano Gear & Maintenance 9 04-10-2013 06:28 PM
Yanmar 3YM20 problem Lathe Diesel 12 01-21-2012 06:31 PM
exhaust elbow yanmar 3ym20 Ceezed Diesel 1 12-22-2011 07:29 PM
