Need help identifying this fuel filter with follow up questions. - SailNet Community
post #1 of 5 Old 04-16-2016 Thread Starter
I'm working on a friends boat; a 1979 Irwin 30 with a Yanmar 2QM motor. It has an odd fuel filter that I can't seem to identify. The sticker says Racor, but it doesn't look like any Racor I can find. No one at the local chandlery seems to know either. See photos below. My question is this; I just popped it open to identify the filter and was wondering if I still have bleed the system if I didn't drain any fuel.
Follow up question; if installing a new filter on the fly, and not draining the fuel, do you have to bleed if you top up the filter before closing it?
Thanks.
Doc_V is offline
post #2 of 5 Old 04-16-2016
RichH's Avatar
Re: Need help identifying this fuel filter with follow up questions.
If this filter element is approx. 5" in length its probably a (Pall Corp) type #4463, single open end - SOE, at 23ÁM abs.100% / 3ÁM 97% 'nominal' retention or 49ÁM abs.100% / 7ÁM 'nominal' 97% rating.
Pretty much an 'industrial' standard 'half size' configuration ..... if its 5" long.
That 4463 designation would be a 2230 if ~2.5" long
Most common filter suppliers can cross reference it to the filter 'lines' they supply, .... if 5" or 2.5" in length.
RichH is offline
The Following User Says Thank You to RichH For This Useful Post:
Doc_V (04-18-2016)
post #3 of 5 Old 04-16-2016
Racor 200 series filter, on my engine changing the filter and topping off required no bleeding.
adki110 is online now
The Following User Says Thank You to adki110 For This Useful Post:
Doc_V (04-18-2016)
post #4 of 5 Old 04-18-2016
JimsCAL's Avatar
This is correct! Had one on my previous boat. Here's a listing for one of the replacement filters. Available in 30, 10 and 2 microns.
Racor 200 Series Aquabloc Fuel Filter / Water Separator Replacement Element
JimsCAL is online now
The Following User Says Thank You to JimsCAL For This Useful Post:
Doc_V (04-18-2016)
post #5 of 5 Old 04-18-2016 Thread Starter
Thanks guys. Yah, that was it. Racor 200FG series. Not to be confused with the newer 200 series; which uses twist on style filters.
Cheers all!
Doc_V is offline
Newbie's first thread :) (((follow up questions))) DavidB.UK Boat Review and Purchase Forum 18 07-02-2012 07:10 AM
Universal diesel Kobuta oil filter is a Fram PH3593A looking for diesel fuel filter dave hirsh Diesel 4 06-07-2010 09:01 AM
Fuel Filter ID? sailak Gear & Maintenance 3 09-30-2009 04:22 PM
Racor fuel filter filter guage Grumpymx Gear & Maintenance 5 08-26-2008 08:10 PM
fuel filter changes stm Gear & Maintenance 3 01-27-2003 12:41 PM
