cold starting woes - Page 3 - SailNet Community
 4Likes
post #21 of 24 Old 04-21-2016 Thread Starter
Re: cold starting woes
Your choice?? Most prefer Jericho. We're in False Creek, but our son is at Jericho (he joined as a youngster)
We moved to Penticton a few years ago, but kept the boat in Vancouver. We end up staying on the boat at the dock quite a few nights throughout the year and Coal Harbour is much less windy, less wear and tear on the boat, and we really like the "feel" of the marina... we can also leave the car in the lot if we go out for a couple of weeks, unlike Jericho where there's a 3-day limit, and even that's kind of a joke as there is a wedding at the club every weekend between April and September that eats up most of the parking. We walked downtown the other night for dinner, it's a nice spot. That having been said, ask me in a year after I've had to deal with the tides under Lions Gate every time we want to head to the Gulf Islands...
Faster likes this.
David Spear is offline
post #22 of 24 Old 04-21-2016
We were at Mosquito Creek for 3 years... you work it out. But going from as much as 45 min to an hour from dock to 'sails up' to 5 minutes has been good, and walking downtown is easy from where we are too. I agree that CH is better for non resident owner.
Hope you sort out the fuel issue...
Faster is offline
post #23 of 24 Old 04-21-2016 Thread Starter
Thanks for your help Ron and have a great season on the water.
post #24 of 24 Old 04-21-2016
midwesterner's Avatar
I could envision a crack or pin hole in the fuel line that could be sucking air while the engine is running, but would be too small to leak fuel. Fuel is thicker than air.
There could be debris in the fuel line, like rust or dead bug parts, that restrict flow enough that it can't feed enough fuel to supply a more fuel hungry cold engine, but is sucked past the restricted area with the added suction of a warm running engine.
My vintage motorcyle has rusty sludge in the fuel petcock that will require me to remove the tank to get to. In the meantime, I've placed an in-line fuel filter in the fuel line to keep it from getting to my carbs. It is a gravity fed system, with the tank sitting above the carbs and engine. The obstruction is just enough to cause fuel starvation when my tank gets below half full. My engine will start running rough and loses power. I can pull into a station and top off the tank and the bike runs great. It also runs rough when it starts and needs a lot of choke. After it reaches operating temperature it runs like a champ, as long as the gas tank is filled above half. It makes just enough extra gravity pressure to push past the restricted fuel petcock.
Rebuilding the mechanical fuel pump could make a big difference, as well.
I owned several VW Beetles in the old days. Even when their mechanical fuel pump was working well, a rebuild every 30,000 to 40,000 made a noticeable difference.
The acceptable pressure range was listed as 8-15 psi. The car would run ok with a pump that tested at 10 psi, but if the engine was older and had other issues, rebuilding the pump to get closer to 15psi made a noticeable difference in cold starting and acceleration.
midwesterner is online now
Starting a Diesel in cold weather okawbow Diesel 12 02-26-2011 05:50 PM
Reverse Woes GaiaOrion General Discussion (sailing related) 9 08-08-2010 11:22 AM
Anchor woes bobdamiano Gear & Maintenance 13 06-07-2010 02:57 PM
Universal M3-20 Cold Starting perlasowner Diesel 7 01-08-2010 08:12 PM
Tacking Woes Dan Dickison Cruising Articles 0 05-19-2002 08:00 PM
