Volvo MD6A Milky Oil - Need Some Advice - SailNet Community
 1Likes
  • 1 Post By Uncle Bob the 1st
post #1 of 10 Old 04-19-2016 Thread Starter
Sailing a Columbia 8.7
Hi,
My wife and I just purchased a Columbia 8.7 sloop a week ago. My buddy had the boat for years but after an accident in the fall, was unable to winterize the Volvo MD6A. The result was "milky oil" in the pan. The boat has not had it's engine ran since that time and rather than giving up, I wanted to learn what might be the cause and see if it can be fixed before I hang an outboard on her for a year.
I've seen some information on the water pump gaskets causing water to get into the oil and wonder if anyone has had the problem with an MD6A or MD7A that was not winterized and what exactly failed.
Any suggestions on how to proceed?
Thanks!
eightpoint7 is offline
post #2 of 10 Old 04-19-2016
kd3pc's Avatar
Re: Volvo MD6A Milky Oil - Need Some Advice
milky oil is always water in it. The challenge is to determine where it is coming from, and how it gets to the oil pan/engine internals.
You do not say where the boat was overwintered, but if it was not winterized and was subject to hard freezing...you may have your answer.
I would borrow or buy a pressure tester to see if that system leaks down, to start with. IF no leak, a good visual of the entire engine looking for oil and water leaks. If the pan can be dropped, you may want to drain the oil and clean any water from the system, make sure the oil level is accurately determined.
Best of luck,
kd3pc is online now
post #3 of 10 Old 04-19-2016
Old enough to know better
Where was the boat. I don't think here in New York we had weather cold enough to really do much damage to an engine this winter. But it does sound like water in the oil. Could be condensation (OK that is the optimist in me) but likely water from somewhere. If it backed up into the exhaust system, into exhaust valves down into the oil it might be ok, but likely at least rusty valves. Also depends on if it is raw water cooled or fresh. Compression test is going to be the starting spot. Does it crank?
1976 C&C 33
Project boat, lots of work to be done!
miatapaul is offline
post #4 of 10 Old 04-19-2016 Thread Starter
Thanks for the suggestion. I am going to get a mechanic and suggest that to start. The boat was in the water but I believe that it was subjected to a hard freeze.
post #5 of 10 Old 04-19-2016 Thread Starter
We were in Maryland. The boat was raw water cooled. I wish it had a heat exchanger. My problems would be less. The info that I got here will help me with my discussion with a mechanic.
Thanks!
post #6 of 10 Old 06-25-2019
Any luck with your quest? I'm having a similar milky oil issue with my Volvo MD6A and suspect a faulty water pump gasket...
Cheers
CatalinaKarma is offline
post #7 of 10 Old 06-26-2019
Originally Posted by eightpoint7 View Post
Hi,
Thanks!
Hi, the fact that the oil is milky indicates that it has water in it, and if you have not run it since you acquired it the problem predates your ownership. if there is a problem that allows water into the oil without the engine being run then the oil will float on the top of the water in distinct layers but if the oil is milky then the water entered whilst the engine was running. If that is the case then a discussion needs to be had with your buddy.
PhilCarlson likes this.
Cheers, Uncle Bob the 1st from Sydney Aust.
Uncle Bob the 1st is offline
post #8 of 10 Old 06-26-2019
3+ yrs, since the OP. They must have figured it out by now.
Agree that it sounds like the engine was likely running with water in it. I doubt that MD temps, especially with a boat stored in the water, are harsh enough to hard freeze and crack a block.
Jeanneau 54DS
Minnewaska is offline
post #9 of 10 Old 06-26-2019
Guess I'm to blame for resurrecting this thread, had hoped that the source of eightpoint7's oil infiltration was eventually determined so that i might test his solution on my MD6A. Wondering if faulty water pump gaskets could indeed be responsible for milky oil in my Volvo diesel as this would be the easiest fix...
post #10 of 10 Old 06-26-2019
My 1st thought on water in oil is head gasket.
I do not know that engine
RegisteredUser is online now
Volvo MD6A over heating sysooke Diesel 11 04-21-2014 07:04 AM
2003 Yanmar, 765 hours - milky oil, overheating, evacuating coolant vpo3 Diesel 2 05-10-2010 11:33 AM
milky oil in a volvo md7 huguley3 Diesel 22 05-06-2010 11:45 AM
MD6A Replacement Oil Filter scurvy Gear & Maintenance 5 09-20-2007 10:57 AM
Volvo intake valves for MD6A not avaiable from Volvo Larrys Pal Gear & Maintenance 5 03-27-2002 05:58 AM
