Fuel care question. - Page 2 - SailNet Community
 8Likes
post #11 of 18 Old 08-19-2016
pdqaltair's Avatar
Re: Fuel care question.
Another thing to remember is that the experience of a regular sailor or cruisers and and occational sailor are not related. A regular cruisers doesn't experiencing long fuel storage. Ironically, it is the non-sailor that has to know about storage.
MarkofSeaLife and Arcb like this.
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
post #12 of 18 Old 08-19-2016
My boat came worth two tanks of 27 gallons each, one under each quarter berth. At 1/4 to 1/2 gallon per hour that's easy more range than I will ever need. I was starting to have filter and rough running problems and traced it to not being able to use the fuel fast enough. My solution was to remove one of the tanks and clean the other. My engine problems went away and I gained some valuable storage space.
capt jgwinks is offline
post #13 of 18 Old 08-19-2016
I've become a believer in a new product called Desl Shok. I've spoken with several boatyard managers that have been impressed by it, particularly for water/moisture. None had any economic interest in the product, but highly recommend I use it. I also hired the company to clean my tank, which did have some water and growth after 10 years.
Jeanneau 54DS
Minnewaska is offline
post #14 of 18 Old 08-20-2016
al brazzi
Who uses Seafoam, I'm not using anything now but would like to.
albrazzi is offline
post #15 of 18 Old 08-20-2016
al brazzi
Originally Posted by aloof View Post
I think the OP's engine is a diesel, folks. So the gasoline comments do not apply.
I don't ever use any additives, but I burn thru the tank several times a year. I do have on valuable comment though for sailors: It is not necessarily what the filter or water separator looks like. It is what the tank looks like. The most common problem is the crud that inevitably forms in diesel tanks has a bad habit of not showing up in the filter until the first rough crossing. Then it breaks free and wreaks havoc.
So take a look in the tank. Older tanks often have considerable amounts of hard resin-like stuff on the inside. That tends to stay put. What you don't want to see is algae mud-like loose stuff. When you are looking take a minute to suck the crud out of the very lowest corner. If it is just clean diesel and maybe a tiny bit of clean water you are good to go. If not, some level of tank cleaning is warranted.
If your diesel fuel is not crystal clear you should dump it (or give to a farmer). By crystal clear I mean not the least bit cloudy. It always has a yellow, amber or dyed red color - but must be clear.
I agree with Aloof, I do think the dangerous ones are large baffeled Tanks on seldom used Boats. The inside of my Tank is spotless Im sure it gets sloshed about quite well every time we go out it gets a 20 degree rinse on every tack.
albrazzi is offline
post #16 of 18 Old 08-20-2016
pdqaltair's Avatar
Seafoam works well for gas, but it has not tested well on diesel.
post #17 of 18 Old 08-20-2016
al brazzi
Thanks it said ALL engines but I trust the community.
albrazzi is offline
post #18 of 18 Old 08-20-2016
al brazzi
I know what you mean, I filled up for a two day race last weekend and still had a half tank from last year when I filled up for the same race. 19 gallon Tank and we use the Boat a lot. when I say use I mean sail.
I did find some stabilizer the PO was using and he kept the Tank full while set up for about a year.
albrazzi is offline
Fuel consumption question davidpm Diesel 85 05-30-2016 11:19 PM
Fuel Polishing Question rbyham Gear & Maintenance 34 12-03-2015 05:23 PM
Fuel consumption question tireman Gear & Maintenance 15 05-18-2011 01:18 PM
Question about fuel usage on a 35' sloop shieek General Discussion (sailing related) 3 07-05-2009 01:18 AM
fuel line question Loualfr Gear & Maintenance 2 09-18-2008 03:14 AM
