Yanmar SB8 issue/questions - Page 2 - SailNet Community
 3Likes
post #11 of 19 Old 01-08-2017
cthoops's Avatar
Re: Yanmar SB8 issue/questions
Originally Posted by mf70 View Post
RE:
Here's the link to the manual PDF:
https://www.dropbox.com/s/ud4t67dds6...12002.pdf?dl=0
cthoops: I could use the parts list PDF as well. Could you post a link?
mark
Hi Mark,
I can't attach a pdf to this post, but if you want to pm me an e-mail address I'd be happy to send it to you.
"Pegu Club"
1977 Bristol 29.9
cthoops is online now
post #12 of 19 Old 01-08-2017
mf70's Avatar
PM sent. Too bad this forum doesn't have a "Files" section.
"Sanderling" 32' Sharpie Ketch
mf70 is offline
post #13 of 19 Old 01-14-2017
lillia28's Avatar
Location: Central New Jersey, sailing on the Navesink River and Sandy Hook Bay mostly.
For what its worth, I just pulled a running (?) YSM 12 from my boat. I also have a YSM 12 head. I'm likely to scrap the engine, so if your interested send me a PM.
lou
lillia28 is offline
post #14 of 19 Old 01-15-2017
mf70's Avatar
The Yanmar SB 8 and 12 parts book is at:
https://www.dropbox.com/s/zph7nid2t2...b8-12.pdf?dl=0
Lillia28: Just curiosity, what are you switching to? I've thought about replacing my YSB12 with electric.
mf70 is offline
post #15 of 19 Old 01-15-2017
lillia28's Avatar
I'm putting in a Beta Marine 14. With an 18 gallon fuel tank that gives about 40 hours of endurance. The only way to get that type of endurance with electric is to install a diesel generator, which will need to be between 12 and 15 HP. You end up with a duplicated propulsion system. If you only want to in and out of your slip/mooring electric works well. If you want to do any kind of long distance sailing, using current technology, it is hard to beat internal combustion.
L
lillia28 is offline
post #16 of 19 Old 02-26-2017
ThanksDad's Avatar
I have a Yanmar SB12 and have post the Owners manual and Parts List here:
Yanmar SB12-Documentation | Sailing "Thanks Dad"
Would love a copy of the service manual if anyone has it.
ThanksDad is offline
post #17 of 19 Old 02-27-2017
lillia28's Avatar
I just found my copy of the YSM 8 & 12 manual, if that will help. Drop me a PM with your email and I'll send it along.
Lou
lillia28 is offline
post #18 of 19 Old 02-28-2017
mf70's Avatar
I posted a link to the service manual on this thread at:
https://www.sailnet.com/forums/3779818-post10.html
You are welcome to download and mount a copy of the manual on your site. The site looks good!
mf70 is offline
post #19 of 19 Old 03-01-2017
Poor gas down the injector holes until you can see it in the hole, try to keep the level in the cylinder up to the hole for 24 hours. After 24 hours try rocking the crank with a tork bar and socket on the crank pulley bolt(not a screw driver). Gas and most loose nut can and will do or any combination. I freed up 2 6v92TA like this and they are still running like champs. Once you are able to turn the motor by hand 2 full rotation of the crank shaft, then leaving the injector out, use the starter to turn it over. (Get your head away from the injector hole, lol). Once you did this for about 20 sec, reassemble and good to go. Unless the cylinder was at TDC or TDB, the rings and oil going up and down got the rust off the walls. Now before you start it, make sure you change the oil. And then about 30 mins after the engine got hot, change it again so no debris, gas or rust can Remain.
Anne Ellis is offline
Tags
diesel engine , engine rebuild , inboard , newbie , yanmar
Yanmar SB8 in portsmouth VA hernando Diesel 4 09-11-2014 03:46 PM
Yanmar SB8 Maintence mandrewman Diesel 5 11-07-2013 10:15 AM
Looking for a Yanmar SB8 diesel Skipper Dave Diesel 2 04-28-2013 01:44 AM
Yanmar SB8 diesel emptycooler C & C 8 11-07-2008 03:58 PM
Yanmar SB8 emptycooler Gear & Maintenance 2 07-15-2008 12:17 PM
