Yanmar SB8 issue/questions - SailNet Community
 3Likes
post #1 of 19 Old 09-08-2016 Thread Starter
Mattybunns's Avatar
Question Yanmar SB8 issue/questions
Hey all. I have an old inboard Yanmar SB8 in my Sun 28 that I am having issues with. First off, I am not very familiar with diesel engines and rely a lot on friends, and here, for help. So, the engine has seized. Pulled the head off and looked at the piston. Springs on the head were a bit rusty, but everything else was fine. Tried to manually turn the crank and it doesn't move. At all. Tried the old WD40 down the cylinder with no luck.
My questions are many, but here's a few off the bat.
1 - Should I take it out and overhaul it? Is it that hard to do?
2 - If I replace it, what's a decent engine I could use while considering the dimensions?
Many thanks!
Mattybunns is offline
post #2 of 19 Old 09-08-2016
bristol299bob's Avatar
Re: Yanmar SB8 issue/questions
I'd say that a simple, one cylinder, diesel like the SB8 is the perfect engine on which to learn. I'd encourage you to pull it and rebuild it. It's not hard to do, and you will learn a lot. Depending on access to the engine, pulling it out might be the hardest part.
Towguy likes this.
1977 Bristol 29.9
Surprise
Hull #5
Oriental NC
bristol299bob is online now
post #3 of 19 Old 09-08-2016
Senior Moment Member
SloopJonB's Avatar
^ This.
SloopJonB is online now
post #4 of 19 Old 09-08-2016
RichH's Avatar
Be patient with the WD40 down the cylinder stuff.
Suggest you try some Marvel Mystery Oil into the cylinder now that you've got the head off.
Just a tablespoon or two to soak the rings and their ring grooves.
DO NOT 'force' the crankshaft!!!!!!
If the engine did not seize while running, just keep adding MMO every few days with an attempt to turning the crankshaft nose bolt with a long handled bar and socket - gently 'rocking' the breaker bar back and forth . It will/may take time; but, it usually WILL free up. DONT force the crankshaft to turn as you will inevitably break the piston rings.
RichH is offline
post #5 of 19 Old 09-09-2016
JimsCAL's Avatar
Some info on what happened to cause it to seize would help.
RichH likes this.
S/V First Tracks
1985 Cal 33-2
JimsCAL is online now
post #6 of 19 Old 09-09-2016
mf70's Avatar
It will be MUCH easier to work on out of the boat. Workshop manuals exist. I've got rough PDF's for the 12...
Sent from my GT-P3113 using Tapatalk
SloopJonB likes this.
"Sanderling" 32' Sharpie Ketch
mf70 is offline
post #7 of 19 Old 09-09-2016
SloopJonB's Avatar
I replaced a YSM (same basic engine) in one of my boats - two guys can easily hump it in & out. Could do it by yourself if your boom is strong enough to hold it.
post #8 of 19 Old 01-03-2017
Sorry to hijack this thread, but I saw you post that you have a rough pdf of the Yanmar SB12 shop manual. I'm burning oil, rapidly, and thinking about replacing my valve guides. Willing to email me a copy of the manual? [email protected]
Thank you so much!
Phil Magistro
s/v Tanager, 1978 Bristol 29.9
pmagistro is offline
post #9 of 19 Old 01-03-2017
cthoops's Avatar
Thank you so much!
Phil Magistro
Phil,
We also have a B29.9 and have a PDF of the exploded parts manual for the SB12 if you think that would help. Let me know.
"Pegu Club"
1977 Bristol 29.9
cthoops is online now
post #10 of 19 Old 01-05-2017
mf70's Avatar
RE:
Thank you so much!
Phil Magistro
Phil,
Here's the link to the manual PDF:
https://www.dropbox.com/s/ud4t67dds6...12002.pdf?dl=0
cthoops: I could use the parts list PDF as well. Could you post a link?
mark
mf70 is offline
Tags
diesel engine , engine rebuild , inboard , newbie , yanmar
Yanmar SB8 in portsmouth VA hernando Diesel 4 09-11-2014 03:46 PM
Yanmar SB8 Maintence mandrewman Diesel 5 11-07-2013 10:15 AM
Looking for a Yanmar SB8 diesel Skipper Dave Diesel 2 04-28-2013 01:44 AM
Yanmar SB8 diesel emptycooler C & C 8 11-07-2008 03:58 PM
Yanmar SB8 emptycooler Gear & Maintenance 2 07-15-2008 12:17 PM
