Leaking Oberdorfer water pump - Page 3 - SailNet Community
 10Likes
post #21 of 22 Old 05-11-2017
Learning the HARD way...
eherlihy's Avatar
Re: Leaking Oberdorfer water pump
Gary is 100% correct about the process to remove the nipple without damaging the threads. But a bigger question is why are you using a threaded nipple instead of a barb fitting? I assume that you are connecting a hose...
Also, you may want to read this other thread; https://www.sailnet.com/forums/diesel...rfer-pump.html
travlin-easy likes this.
USCG Licensed OUPV Captain, ASA 101/103/104/105/106/114/118 Instructor - Also certified in Marine Electrical Systems
eherlihy is online now
post #22 of 22 Old 05-13-2017
RichH's Avatar
Originally Posted by jballou View Post
Also - does anyone on this thread know if there needs to be a gasket between the pump body and the engine? My Oberdorfer manual doesn't mention a need, and I have never seen a gasket part anywhere.... ?
A fiber gasket is the most convenient and quickest way to keep the oil from leaking/seeping.
An alternative way, increasingly popular within the automotive market, is to use automotive grade (black - Permatex, etc.) silicone-RTV, as a gasket substitute. Apply a bead of the silicone (aka: 'black death' or 'monkey crap') to the sealing surfaces, tighten down PART WAY (leaving "ONE thread loose"), let the silicone fully cure, then finish tightening after the silicone has become fully cured. Such silicone cures in the presence of atmospheric 'humidity' - so spritz/mist the assembled parts with water on the exposed silicone to accelerate the curing process.
RichH is offline
The Following User Says Thank You to RichH For This Useful Post:
jballou (05-22-2017)
rebuilding Oberdorfer Pump anemoneii Diesel 57 06-29-2016 09:28 PM
Help! Leaking Injector Pump Classic30 Diesel 87 03-31-2014 01:29 PM
oberdorfer water pump joedbe Atomic 4 3 07-31-2012 12:40 AM
Leaking water pump. L124C Diesel 19 08-08-2009 01:00 PM
Fresh water foot pump (Whale) leaking josrulz Gear & Maintenance 4 05-18-2009 08:37 AM
