Engine alarms and tach inop - Page 2 - SailNet Community
 2Likes
post #11 of 12 Old 07-13-2018
Dirt Free
boatpoker's Avatar
Re: Engine alarms and tach inop
Originally Posted by Cal39Tantrum View Post
I just got a cal 39, and im having a similar problem...when i fire up the ole perkins, no alarm...not entirely sure how the doctor that owned it before ever could feel comfortable with no op/temp alarm!
Anyway, does anyone know where I can get a buzzer/bell? also a hi temp sensor and lo pressure sensor?
Thanks!, Jim
I've never understood why so many small diesels are sold without oil pressure or temperature gauges. By the time your overheat alarm goes off your engine is already overheated.
I would not leave the dock without a raw water alarm which will sound off the instant raw water ceases to flow..... long before the engine overheats.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #12 of 12 Old 07-13-2018
JimsCAL's Avatar
A kit like this is probably the easiest way to go.
https://www.amazon.com/Sierra-Intern.../dp/B001RIJMIA
S/V First Tracks
1985 Cal 33-2
JimsCAL is online now
The Following User Says Thank You to JimsCAL For This Useful Post:
Cal39Tantrum (07-14-2018)
Replacing the Tach; Universal 5411 "Tiny Tach" jrhamp Diesel 3 10-23-2012 12:26 AM
Changing Out Engine Gauges/Tach Problem H2814D Diesel 3 03-13-2012 08:09 AM
Audible engine alarms - not always installed? mbsl98 Gear & Maintenance 6 06-28-2011 06:25 PM
Classified section inop? kevinH23 Hunter 0 01-13-2011 01:10 AM
desiel tach: Tiny-tach dreuge Diesel 5 04-30-2010 11:04 AM
